Question about Garden
Briggs and stratton 3.5 hp will not start.less than24 hours on engine. changed plug air filter new gas plug fouls out checked for fire from coil. hard to start.
TOOK IT TO A MOWER SHOP EXPERT.
Posted on Sep 14, 2009
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
I have a B & S vanguard 20 H.P. vert. shaft, 8 years old on Simplicty tractor. Keeps fouling plugs. Clean or replace plugs and it runs fine for about 1/2 an hour then starts to miss, blacksmoke, and...
Anti-foul plug adapters might be a temporary solution (treats the symptom and not the cause).
Personally, I would take it to a good, reputable, small engine repair shop that has verifiable references, and have them repair it.
Aug 03, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Lawn mower won't start
to check for firing remove the spark plug insert it in the plug boot and pull the rope while watching to see if the plug sparks be carefull not to touch the plug electrode while pulling the rope or it will shock you. If you don't have a spark, try a different plug. If still no spark the coil could be bad.
Jun 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine turns over but doesn't fire.
check it for spark then check if it is getting fuel cuz that might be the problem
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Lawn mower will not start
check gas tank with light is there dirt in tank? did you change fuel filter? is there spark at the spark plug? try a 2 second spurt of starting fluid in carburetor and crank does it fire?if it does then you most likely need to clean carburetor with carburetor cleaning spray, flush fuel lines with spray and swap fuel filter.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Oil in air cleaner
Run it minus an air filter until all the oil is off your piston head, you can also try keeping the plug out and ejecting the oil via that access by pulling the cord. It seems like you've already solved the problem, now you're just cleaning up.
Apr 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My B & S fouls plugs, runs rough, almost stalls when blade
THE PROBLEM SOUNDS LIKE THE CARB IS RUNNING TO RICH OR TO MUCH GAS IS BEING PUMPED INTO THE CYLINDER. IS THERE ANY SMOKE AND WHAT COLOR SMOKE
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
150 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
