Question about Garden
Honda Lawn Tractor 2216 won't start
Have had to return this machine to the 'professionals' to clean the carb twice within the last 6 weeks. Won't start today. Plenty of fuel running to the carb and a new battery. Can I clean the carb myself?
  • 389 Answers
If you have had to take it back twice, I would say they are not doing a very good job. I would clean out the fuel tank and if possible, install a good inline fuel filter between the tank and carb somewhere.
You can clean the carb yourself if you have some basic mechanical knowledge and metric tools. The main thing you need to do is remove the float bowl and clean it out, then remove the main jet from inside the center of the carb body and clean it out. Try to do this without removing the carb from the engine because getting it off the engine can be a tricky frustrating job if you don't know the little "tricks" to get the linkages disconnected
Posted on Sep 15, 2009
Testimonial: "Thank you for your clear and concise reply. The mower decided to start before major surgery on the carb and has mowed 2 acres effortlessly! "
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
Motor power suging up an down
Its in the carb linkage which controls the choke and the throttle position..its just a pain to use it.. won;t hurt anything.
hard to imagine people still buy larger items from sears these days..sorry...
Sep 11, 2017 | Craftsman YT 4000 42" Briggs Stratton 24...
Honda hrs 21 poor spark
Be aware that some Honda engines like the HRS21 have plastic carbs and needle valves. Watch what your soaking them in because it can eat them up, destroying them.
Mar 10, 2013 | Garden
I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Feb 23, 2013 | Garden
Lawnmower won't start. There is no primer bulb,supposed to start on first pull
Do you have fresh gas? Make sure the choke on carb is working, maybe drain the gas out of carb and or clean it out, check for spark
Aug 19, 2012 | Snapper 20 HP Lawn Tractor 2690578
Not Staying Started
I can't tell you how many pieces of small equipment I have been given for free because it "just won't start" or "won't stay running". Start by draining the tank and cleaning it out - use a good carb cleaner. It only takes a grain of sand to create a problem. You may have to take the carb apart and clean that out too.
Aug 01, 2012 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
My 26 hp tractor stalls and won't start when it gets hot
is there spark?is there fuel threw the carb?
May 01, 2012 | Craftsman Garden
I bought a craftman lawn mower 6.75hp. I only used it twice, and then I let the lawn mower set in my garage for about 6 years, with the gas and oil in it. Now it won't start, and I did get it to start...
If it has been stood with the same fuel in it for any lenght of time, then the fuel will go bad, drain the fuel and re fill with fresh fuel, if there is a bowl drain on the carb slacken this and drain the bowl, now try again, if it does not sort itself out after a lenght of running then will need to remove the carb float bowl and blow an air line through the jets.
Feb 29, 2012 | Craftsman Garden
Garden Logo
175 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
