Question about Sony Televison & Video
Disc stuck in machine. took off cover. can see
Disc stuck in machine. took off cover. can see disc. how does it release?
  • 52 Answers
Find the electrical motor and try to turn it with your fingers, it should move the gears in order to release mechanism. It its stops and no movement, turn the motor the other way.
Posted on Sep 12, 2009
  • ronhicks1979
    ronhicks1979 Jul 09, 2012
    I had this same problem once, there should be 2 screws that holds the top cam in place. remove the 2 screws then the cam, this should allow you to remove the disc without damage or risk of scratching it.
Stuck closed, how to open?
press release on top cover , I had someone use mine 1ce and they pressed "seal" with no bag in machine it did exactly that it stuck closed, tight too !! one touch of release button on top cover and it popped open
Jan 15, 2016 | FoodSaver V3250 Vacuum Sealer Kit
Rotor cover stuck
the cover is probably twisted or stuck on the sline get it even and just keep pulling at it
Sep 03, 2015 | Fisher and Paykel Washing Machines
How do you open the base unit to remove the cd changer magazine
The top cover is held on with 4 clips (similar to those on a car door card) so needs to be gently prised off, this will expose screws etc to enable the bottom cover to be removed.
Ive done this with my system but it does not really help solve the problem, I still can't get to the jammed disc!!
Jul 07, 2014 | Bose Lifestyle 30 System
Disc stuck in cd changer
there is a large gear on the top of the cd mech, turn it counterclockwise to put the cd back in the magazine. the changer will probably work after that.
May 09, 2009 | Car Audio & Video
Philips DVR model HDRW720/17 Display screen shows "Blocked"
Do you have a disc locked up inside? I found that there IS a manual release for the disc tray UNDERNEATH the unit. It is a sort of toggle lever that you have to slide to the other side and that releases the disc. The Manual does not even mention this manual release lever!
Also, it may be hidden or covered by a paper like cover.
GL
Oct 30, 2008 | Philips HDRW720 DVD Recorder
NAD 502 CD player problem
Does it have a failing drawer belt? My 522 was fixed after that.
Jun 18, 2008 | NAD C521 CD Player
Locked??
I had this problem, it was a jammed disc. I disconnected the dvd player and removed the cover. Then I checked out the trays and sure enough a disc was jammed. It took a bit of very gentle work to free the disc as the jammed tray needed to be unlocked so the tray self slid and released the offending disc. Once that was done I placed the cover back on and reconnected the wiring...and all was well.
Jun 02, 2008 | JVC TH-M606 System
Go Video VR 1940 DVD Recorder + VCR - DVD disk will not eject from slot on top of flat screen TV
My sugestion is to open the dvd player cover, then after you remove it the disc cover you screw out it to remove your disc.
Apr 24, 2008 | GoVideo Go Video DVD/VCR Combo
Error message
I had this happen to me as ell. you've probably got a cd stuck under the revolving tray. I took the top cover off and then opened the drawer and removed the offending disk. If you're not technically minded it's probably better to take it in to a repair shop. Mike
Dec 24, 2007 | Marantz CC-4300 5-Disc CD Changer
Disc Eject won't work after improperly inserting disc and since removing it.
I have an DZ-MV780 with the same problem. I found that the cover plate around the flash hot shoe only has a single screw. If you remove it and pull up the cover you gain access to the gear and lock mechanism. Hit eject and if necessary press on the white gears you see in front of the zoom switch. It should then cause the door mechanism to unlock and open.
Aug 24, 2006 | Hitachi DZ-MV580A DVD Camcorder
Televison & Video Logo
146 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
