Question about Nintendo Wii Console
Power light went out and won't come on. Hasn't been played for a while. it is a wii model rvl-001[usa]
Wii control doesn't turn lights on. if you twist it a bit, the lights go on. must have something a bit los inside. no tec service here
Posted on Sep 13, 2009
How do i fix a Wii
Try this. What are you trying to fix? You may not have to tear it apart.
Apr 03, 2015 | Nintendo Wii Console
Model rvl 001
Check all the connections of the cables from the wii to the television to its power source. You can also test the outlet that you are trying to use by plugging something else into it. You may find that the wii power cable will not send power to the wii and needs to be replaced.
Apr 11, 2014 | Nintendo Wii Console
Model rvl 001
Netflix is not pre-installed on the Wii. To install it, launch the Wii Shop Channel and click "Channels", then select it from the list (it is a free download).
Jan 31, 2014 | Nintendo Wii Console
I have a Wii game system model No. RVL-101 (USA) how do u get it to work
ok so u start to plug all the wires in the TV.theres a sensor that u need to put in middle of the tv.the sensor is like a rectangle and very lite its supposed to have a wire that has to be plugged in the wii not the TV.
after that its time for your controllers.you need to have at least one controller to play wii.you need to put two batteries at the back of the controller.then click the power button and you'll see the 4 lights light up,but then after seconds there supposed to be 1 light lit up.when your done than click the power button for the wii.for the controller to work u should turn on the wii before the controller.Then the easy part take the cd(game)and put it in the wii.
Dec 06, 2013 | Nintendo Wii Console
My Wii will not let you insert any discs.
Discs Eject on Their Own
Situation:
Game disc is ejecting on its own
Applies To: All Games
Important!
If the game disc is ejecting on its own, this could indicate a problem with the disc or with the disc drive.
What To Do:
If you are experiencing this problem while attempting to play a Nintendo GameCube Game Disc, check the model number on your Wii console. Only Wii consoles with model number RVL-001 are compatible with Nintendo GameCube Game Discs. (learn more)
If the issue is occurring with all games or all of one type of game (Wii or GameCube), this indicates a problem with the system. To begin the repair process, click here.
Nov 16, 2012 | Nintendo Wii Console
How can I play with rvl 101 wii using copy dvds ?
Wii consoles with the RVL-101 drive will not play copied discs at all, no matter what you do.
May 07, 2012 | Nintendo Wii Console Rvl-101
Where can I find a user manual for my Wii RVL-001 (USA)?
These work for all type of wii models
http://gamesites.nintendo.com.au/support/Wii_Operations_Manual-SystemSetup_AUS.pdf
Thanks
1RepairStop.com
Feb 15, 2012 | Nintendo Wii Console
I can't connect my controller to the wii console. Model number Rvl-001(USA). Model of nyko pistol accessory is Bn:090907 4632.My mom threw out the manual out by mistake.HELP!
  • Turn on your Wii console. While on the HOME screen, press any button on the Wii Remote.
  • If the 4 squares on the bottom remain dark, change the batteries (or for a rechargeable Wii Remote, place it on the charger for a while).
  • If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
  • If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
  • Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console.
May 13, 2011 | Video Game Consoles & Games
My wii is not working, we turned it off one day and it did not turn back on when we went to play it. Now the light won't come on and everything is pluged in.
No Power
    Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
      1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
      2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
      3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
      4. While you're waiting, check the AC Adapter for the following:
        • Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensedproducts are not fully compatible and may not work correctly.
        • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
      5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
Jan 01, 2011 | Nintendo Wii Console
I can't get the hand to show up on the screen. Wii fit nintendo 2006 model model # rvl-001(USA)
Check to make sure your light-bar is plugged in securely (the thin sliver bar that you put on top or below your TV). The wire for this is quite thin, so make sure there are no punctures and cuts in it. I hope this helps!
Here is a link to Nintendo support:
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
Here is their support phone #: 1-800-255-3700
Oct 12, 2009 | Nintendo Wii Fit for Wii
Nintendo Wii Console Logo
472 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
