Question about Husqvarna Garden
Engine cuts out
Engine cuts out when the deck is lowered
  • 148 Answers
Have you checked the safeties? In particular the rider presence switch (under the seat).
Posted on Sep 12, 2009
Why is it that my riding Lawnmower doesn't cut when I lower the deck to cut the grass lower
Tighten or replace drive belt. Before you do that though, with the deck raised right up and engine switched off reach underneath deck and grab hold of blades and try to move them up and down. Make sure there is no build up of debris between pulleys and guards. Remove the belt off pulleys if you can. Turn blades and check they are free to turn. What you are doing here is checking the blade spindle bearings for wear or damage. If they have excessive movement or feel rough and/or tight replace them. If they are good and the belt looks in good order, tighten belt That is done by adjusting the deck rods so the deck moves back. You tube have some videos of belt adjustment.
Aug 22, 2014 | Garden
Riding mower deck height too low
If you have removed the cutting deck for any reason you may have put the deck arms in the wrong knotch.
Apr 08, 2017 | Yard Man Garden
Ride on mower engine cuts out when lowering cutting deck
hi there
pauly 46 here
off the top off my head - if the tractor starts with the pk brake on , and the operator in his seat,
and you try ty lower deck ( which operates another switch ) it maybe the seat switch is playing up
try pulling the wires off the connector @ the seat switch and retry deck lowering-?
then try fitting a jump wire accross those two connectors you just disconnected at the seat switch and retry
if not check that your switch that is activated when you lower the deck is not stuck closed ?
if not check that your pk brake switch is not stuck closed (it should normally be open when tractor is in use with user in seat, and deck engaged and in gear )
check that all belts / pulleys and blade spindles turn freely and are not siezed / damaged
other than that dont know how else i can help ?
cheers pauly46
May 06, 2011 | Garden
LA110, 42" mower deck, 1
Check that the cutting tip of the blade that is cutting lower is not bent down. Also park the mower on a level surface and lower the deck and check the gap under the front of the deck is even. If not, there are levelling adjustments on the top of one side of the deck. Regards Phil
Apr 15, 2011 | John Deere 195HP Hydrostatic 42" Cut...
Deck blade on driver side is lower why
never heard of that sound like problem to me.might have lost a hitch pin in the mowing deck which has caused it to drop on one side or end
Apr 22, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Blades slow down when cutting deck is lowered.
the lowerer the deck the more your working the mower. either mow more often or reduce speed
Oct 22, 2009 | Garden
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed My mower is a 42 cut and leave a row in the middle of the cut
SOUNDS LIKE YOU HAVE A BENT BLADE TRY PUTING A 2X4 UNDER THE DECK THEN LOWER IT TO HOW IT LOOKS IF ITS THE SAME ON BOTH SIDES THAN YOR BLADE IT BENT
Sep 30, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Ride on Mountfield Lawn mower 1228H - engine cuts out
Check to make sure there is no obstruction in the blades or on top of the deck where the belt goes. Also check that your pulleys turn freely and that a bearing didn't freeze up.
Let me know if this helps.
roundo4
Aug 08, 2009 | Garden
Garden Logo
57 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
