Question about RCA F32650 32" TV
Stuck on channel 3
I have lost my manual, and my remote cannot turn the channels (turns tv on and off and adjusts volume). Trying to change channels with the bottons on the bottom of front does not work either, stays on channel 3. How can I get it to channel 0?! Thank you Steve
  • 1,694 Answers
Set-up in menu = step thru each page = skip what does not
apply to you = get to sure signal is attached
to set first.........................T.
Posted on Dec 11, 2007
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2, stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
Remote fall on floor and now it is stuck on one channel and I can not turn off the TV or change a channel or lower the volume
Hi, well you can do everything from the axtual TV itself, have a look on the TV you will find a setof buttons/keys. these allow you to controll almost everything that the remote can do.
here you can change channel change volume etc.
The buttons usually there are 6- 7 marked On/Off, Channel up/down, Volume Up/Down, Enter/OK & Menu. Now pressing these will bring up the onscreen display and you can adjust what you wish.
Now with the remote, it's probably best to obtain a new one..
Sometimes disassembly may fix it, but it sounds like it has a bad problem.
To ensure it doesn't interfere remove the batteries.
Aug 19, 2010 | Televison & Video
My brighthouse remote can turn my tv on and off but not change channels
The remotes have several device keys at the top of the remote. They have abbreviations like "VCR", "DVD", "TV", "CBL". By default some actions are locked into a specific key. By default, the volume buttons will always control the TV volume and the channel buttons will always change channels on a digital box.
If you have a digital box, and the channels wont change, the default locks might have been removed. Consult the instruction manual that came with the remote and re-lock the buttons to the correct device key. Otherwise you will need to press the "tv" button when trying to change volume and the "cbl" button when trying to change channels.
If you do NOT have a cable box and are just simply trying to use the universal remote as a primary remote, you will need to unlock the global channel lock. Consult the manual for the remote or check online for the remote guide. The Company which makes the remotes is called Universal Electronics and you can find digital copies of their manuals on the Brighthouse Websites.
May 20, 2010 | Sylvania LC320SS8 32 in. LCD Television
Good day,
I might be missing something here, but if YourTV has the basic controls on the TV itself, such as on/off volume, and channel select, then just turn on tv, and set it to channel 3.
Use your converter box remote to scan for channels, and other options it has as needed.
Jan 23, 2010 | Televison & Video
Child lock is on lg tv and have lost the remote
My child lost the tv remote and we have the child lock on so we can;t change the channel or the volume. Do you know how to turn it off without the remote?
Apr 10, 2009 | Televison & Video
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum ( and it fixed my remote problem:
"'s possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Lost Remote
I personally would get myself a "Universal Remote". These units will operate almost ANY unit that uses Infrared... Ya Punch a "Code" in for your particular TV etc, and thats it... total conrtol...
Sep 22, 2007 | Sharp 32R-S50 32" TV
RCA F32650 32" TV Logo
101 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
