Question about GE JTP45 Electric Double Oven
Install new element in upper oven lower element
How do you install the lower element in the upper oven on a ge Mod#jkp28wof1ww
  • Anonymous Mar 29, 2014
    how to install new bottom element
    President:
  • GE Master
  • 1,922 Answers
Unplug unit from 240volt outlet or if hardwired shut off circuit breaker at house panel, remove 2 screws at where element leads enter oven cavity and pull out element,you may have 2 terminal screws to remove electrical connections from element if it doesn't plug-in, then reverse procedure and its done
Posted on Sep 13, 2009
GE True Temp lower element not working after being replaced
sounds like you got a defective element
Feb 08, 2018 | GE Ovens
GE stove model GRSR3620SM-2 Self Cleaning Cycle Not Working.
my first thought would be a loose connection at the element or main power terminal. it could be a relay board issue also
Jan 08, 2012 | GE Profile JTP18 Electric Single Oven
GE Profile JTP85 (installed 1998). The lower heat element in the lower oven will not heat. I can make the upper element heat up by using the BROIL function, but neither element gets warm on BAKE.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 11, 2010 | GE JTP85 Electric Double Oven
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Nov 08, 2010 | GE JKS05 Electric Single Oven
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
Is it easy to replace the lower element on a jtp 15 GE oven? While the wife was baking last week, the lowere element burned out. Was wondering if I could replace it myself
Easy replacement. Make sure to unplug power or shut off breaker. remove 1/4" hex screw on back of element. Pull off female terminals or some have screws. Install new element the same way.
Mar 23, 2009 | GE JTP15 Electric Single Oven
Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Dec 27, 2008 | GE JKS05 Electric Single Oven
Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Nov 17, 2006 | GE Profile JTP56 Electric Double Oven
GE JTP45 Electric Double Oven Logo
355 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
