Question about Nikon Super Coolscan 5000 ED Film Scanner
My scanner wont let me scan. It says "Photoshop has encountered a problem and must close. Describe the problem for Microsoft... send report (or not). I have run the installation-cd for Nikon Scan 4.0 again but nothing works. If I try to scan directly (and not PREVIEWING where the program crashes as above) I also get a message: There was an error in performing a scan. What can I do? There is no software to download for the scanner anymore on Nikons site? Regards, Helen
    President:
  • 1,462 Answers
I think, when you apply the processing to 1 image it works, but trying to do it on a 2nd image would result in that error message..
Heres the solution for the crashes:
The real issue so far was with the bundled Nikon Scan software crashing. In particular which using the GEM/ROC on more than one frame at a time. It seemed to only apply GEM/ROC to one frame before crashing. Turns this is a common problem caused by an incorrectly versioned DLL in the windows\system32 folder. Replacing the DRAGNKL1.dll file in system32 with the DRAGNKL1.dll from the Nikon Scan folder in Program Files solved the problems. (Note, if you haven't installed Nikon View, this may not be a problem.) Remember, always backup the files before you make any changes. (end of copy-n-paste) Why this information is not in Nikon's knowledge base is beyond me.
The only deviation from these instructions is that the correct version of the .dll file was in my c:\Windows\twain_32\nikon\nikonscan\ directory. Replace the version in the system32 directory
This could solve the problem...
If this doesnt work, then you can repair your DLL and driver from the follwing link,
http://dllinfo.dll-free-download.org/n/57536-nikon+scan.exe.html
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Sep 12, 2009
How do I delete the error reporting to microsoft
if it is Showing ” Internet Explorer has encountered a problem and needs to close. We are sorry for the inconvenience ” Click “Don’t Send ” and everything get closed ,This Window error Report generated by microsoft is sometimes create problems for you , it is suggested you to dont ever click Send Error Reports or ” Please tell Microsoft about this problem ” because it will send all yours computer details to Microsoft , and creating problems for you.so its better to disable that error repor,so that such problem not arise in future,There are three methods to disable Microsoft error reporting.
  • To get rid of this MS Error Reporting, Right-click the My Computer icon on your desktop and choose Properties.
  • In the System Properties , go to the Advanced tab and click Error Reporting.
  • Select disable error reporting This will make any crashing program’s window simply close itself.
  • You could also click But Notify Me When Critical Errors Occur, but it might be even safer if you select Enable Error Reporting.
Inspite of this technique you can also disable error reporting via control panel as well as via editing registry . icon_smile.gif
Tags: Dont Send, Error Reports, Microsoft, Window Error
May 19, 2010 | Computers & Internet
Software micrsft lifecamvx1000 wont open when webcam is connected
Get Amcap this will give you the ability to record video and see the web cam.
amcap.en.softonic.com/ - United States
Mar 10, 2010 | Microsoft LifeCam VX-1000 Webcam
I've installed the latest version of msn yesterday. 5 seconds after i sign in i get the ''Windows Live Communications Platform has encountered a problem and needs to close. We are sorry for the...
Although the solution is being posted months after the question is raised, let this help others having the same Dr.Watson issue.
For this, you can ignore the Error Reporting window, or turn off error reporting so it wont dump your windows drive with GBs of unwanted error dump data. If you are good with Registry Editor, follow the steps below:
Open your Registry Editor and browse to
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionAeDebug . Create a new string value (REG_SZ) with name 'Auto' and enter its value as 0, so error reporting gets disabled.
May be this article should help you.
Oct 06, 2009 | Microsoft Windows Live Messanger
HP deskjet f2280 won't scan
you can try clicking MY COMPUTER then C: then PROGRAM FILES then Hp then Destination folder then bin then find the hpscnapp with a printer icon.Scan will work.Hp 2280 frequently encounters error especially if you're using VISTA. Hope i helped! Good day!
Aug 04, 2009 | HP Office Equipment & Supplies
I have the Acer S2W 3300u scanner and although I installed the drivers for Windows XP, it shows the error message "EXE application has encountered a problem and needs to close. We are sorry for the...
I have the same scanner and the drivers that came with the scanner don't work. Windows XP uses a generic twain driver that works, also most pictures viewer like XnView or Picasa uses the same. I'm using one called Wia-flatScanner_21 1.0(32-32).
Apr 01, 2009 | Acer Scan to Web 3300U Flatbed Scanner
Microtek scanner freezes when scanning large documents.
Try scanning using Scanwizard instead of using directly in Photoshop. If it freezes again, it might be some problem with your system since there's no indication of hardware conflict. Additional info like Microtek scanner model name and current Windows version. Normally, Adobe wont have any problem regardless the scanner model, as long the appropriate driver installed.
Mar 27, 2009 | Microtek ScanMaker 5950 Flatbed Scanner
Message: Outlook Express has encountered an
Most likely there is a email with a virus in one of your outlook express folders. Download a 30 day trial of Kaspersky internet security and run a full scan on your computer.
Alternatively, you could try creating a new Identity in outlook express, only problem is you wont be able to access your old emails. But you can always switch back and forth. To do this Click on File – Identities – Manage Identities. Here you can create a new one and configure your email settings. Though this may work, this may only be a temporary solution.
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 05, 2009 | Microsoft Windows XP Home Edition
Problem With My PC
When did it first start happening?
Do you have restore points activated? Try restoring your machine to an earlier date to see if it fixes the problem.
Feb 05, 2009 | Microsoft Windows XP Professional
CanoScan LiDE 20
already install the scanner driver but still can't working properly.
Sep 04, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Open Questions:
See all Nikon Super Coolscan 5000 ED Film Scanner Questions
Nikon Super Coolscan 5000 ED Film Scanner Logo
268 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Ric Donato
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
