Question about Lexmark X5070 ALL-IN-ONE InkJet Printer
No power to my x5070
Is there a reset button I need to push or what? We might have lost power a some time, but I don't think so.
Tom tom wont turn on
Test your Power Cable for Voltage Out. If it is working properly, then your TOM TOM bit the dust but I am thinking that you are out of Power and will not turn back on unless you get her charged up.
If it is charged up, then PUSH and HOLD the POWER BUTTON for 30 Seconds and this is how you RESET the GPS.
If resetting does not work, and you have Power. Time to get a new GPS. Sorry
Mar 01, 2014 | Pantech Ease P2020 AT&T
How to reprogram htc evo when i don't remember my google account information?
IF YOU CANT GET IN TO THE PHONE U CAN DO A (HARD RESET)
THIS WILL RESET THE PHONE AS IF IT WAS NEW IT WILL DELETE EVERY THING ON THE PHONE TO DO THIS U NEED TO TAKE OUT THE BATTERY IN PUT IT BACK IN HOLD IN THE VOLUME BUTTON IN PUSH THE POWER BUTTON IN WHEN IT COMES ON PUSH THE POWER BUTTON THEN PUSH THE VOLUME DOWN TWO TIMES IT SHOULD MOVE DOWN TO CLEAR STORGE PUSH THE POWER BUTTON THE PHONE WILL REBOOT BACK TO LIKE NEW
GOOD LUCK
Oct 08, 2011 | HTC EVO 4G Smartphone
Error 5200 or PO8?
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 12, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have a canon pixma mp250 and error P07 flashing.Now,I refill blac and colour cartridges,and clean ink absorber,but still flashing P07.How to reset printer? Best regards, Misko
its mean absorber full..(i think)
Check this steps :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
1 Press the power button to turn off the printer.
  • 2 Hold the "Stop/Reset" button while pushing the power button. While still holding down the power button, release the "Stop/Reset" button and then push it twice in a row.
  • 3 Wait approximately 20 to 30 seconds until the LED shows 0.
  • 4 Push the "Stop/Reset" button four times in a row.
  • 5 Push the power button twice.
  • 6 Turn off the printer by pushing the power button one more time. The printer is now reset. Next comes resetting the counter on the cartridge.
  • 7 Unplug the power and the USB cables from the printer.
  • 8 Open the cartridge door and hold down the power button.
  • 9 Reconnect the power cables while still holding down the power button.
  • 10 Close the cartridge door and release the power button. The ink cartridge is now reset.
  • Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    I have a AIWA X204 CD in my car.I don,t know what I did, but the player doesn't answer to any comand. i push every one of button, but he don;t start to play.The screen it's light up,, and...
    I think that's Demo mode.
    I got stuck there too.
    This is what worked for me:
    1. Power the radio off (hold the power button in top left corner in for several seconds)
    2. Remove face plate
    3. Hold in reset 10 seconds
    4. Press push-menu dial/button 3 or 4 times
    5. Insert cd and hit source to switch to tuner before cd starts
    Not all of these steps may be necessary.
    I suspect having the power off before the reset button was the important part.
    Jul 26, 2011 | Aiwa CDC-X204 CD Player
    I AM TRYING TO RESET MY PRINTER X5070 LEXMARK
    Hi there you can try.
    How to Restore the Printer Settings on the Lexmark X2600 Series All-In-Ones to the Factory Defaults
    Step
    Action
    Turn off the power to the printer.
    Press and hold the Color Copy button:
    Press and release the power button:
    Once you see a '0' on the display, release the Color Copy button.
    5
    Press the up arrow button until a ' 5' appears on the display.
    6
    Press the Black Copy button to restore the printer settings to the factory defaults. When the reset process is complete, the printer will automatically reboot.
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Feb 09, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
    I swapped Photoconductors from 2 other 1710's; no go. Reset?
    Problem
    Dell 1700 printer prints out a page announcing that “the photoconductor has reached its useable life and it needs to be replaced for a new one”. You replace the photoconductor for a new one and the error light is still blinking and the printer keeps on printing the above mentioned page.
    Solution
    Steps to Reset the Photoconductor:
    1. Power off printer
    2. Open the front cover.
    3. Press the continue button; while pressing the continue button power on the printer and wait (still pressing the continue button) until the error led is solid, then release the continue button.
    4. Close the front door, all light should be solid.
    5. Wait until POST finishes.
    6. Press the Cancel button 4 times slowly, the toner led should be solid.
    7. Press the Continue button until all lights go up and down, then release; the Toner Low led is solid.
    8. Power off printer and then back on.
    9. Press continue button once, print a test page.
    10. Check the information about the photoconductor in test page, it should display an OK status.
    Note: if these steps don’t work for the first time repeat three times. If still the steps don’t work, the printer needs to be replaced for a new one.
    Jun 26, 2009 | Dell 1700n Laser Printer
    Cannot receive faxes on Lexmark x5070 All in one
    Clear NV RAM..... Unplug the Power Supply from the Printer.... Press and Hold the #5 button on the Printer and plug in the Power Supply....... Don Release the #5 button till the Printer turns on completely.... After releasing the #5 button........ Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option  saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM.....
    Now as soon as the Printer is Restarted....... U will be able to send and recieve faxes..... Thanku.............
    Jan 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
    Installation
    Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
    Hope this helps. Bud
    Jan 09, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
    Lexmark X5070 ALL-IN-ONE InkJet Printer Logo
    100 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
