Question about Leviton 8599 GFCI Receptacle
HP Sodium Security light keeps going on and off
We have two 70 W HP Sodium Security lights. They worked well fot the first eight months. Now they go on and offl sometimes there is only a glimer of light. TIn the last few days, one has'nt come at all. We have replaced the bulb but to no avail.
  • koturbash Sep 26, 2009
    The lights have been ib service for only ten months. I would think that the life expectancy of the components would be longer than that. weve just had the complete units replace under warranty. We'll see what sevice we get out of the new ones.
  • 4,340 Answers
Typically, the transformer fails. As bulbs become older, the power to run them goes way up, overloading the transformer....
Posted on Sep 25, 2009
When could I get an answer to my question
Have you tried contacting the manufacturer?
Oct 05, 2015 | Home
I have 115 v at the bulb receptacle but the bulb doesn't light up...whats the problem its a rab ff150 hps fixture
Does the bulb work in a different fixture? Sometimes the base of the bulb does not make contact with the terminal inside the fixture. unplug the fixture and then see if you can bend the center "not" connector up a little.
Nov 08, 2014 | Rab Lighting RAB FF150 - 150 Watt - High...
What causes outside cooper MD series security light to flicker during night
If this uses a high pressure sodium lamp, it usually means that the lamp is going bad and needs to be replaced. If the lamp is good, check that it is tight in the socket. The other possible cause would be a light shining on the photo eye, if it is photo eye controlled. You may have to rotate the photo eye to face away from the light source.
Jul 08, 2014 | Home
Lithonia photocell light stays on during the day
1) Buy twist-lock photo control:
http://www.intermatic.com/en/Products/Sensors/PhotoControls.aspx
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Dtools&field-keywords=twist+lock+photo+control
2) Spray bit of WD40 on twist-lock blades before installing new photo eye, and then rotate back and forth a bit to make sure there is electrical contact.
Test by placing black tape over photo eye.
Feb 14, 2013 | Hardware & Accessories
What is a sodium vapor lamp?
There are two types of sodium vapor lamps, the low pressure sodium and the high pressure sodium. Both types are very efficient, in fact they are the most efficient bulbs made today. The sodium vapor cost around 80$ the bulb and the ballast and a spare bulb will cost you around 30 dollars.
Aug 21, 2012 | Fish
1997 oldsmobile 88 won't start the security light
Im guessing you tried to bypass the key in the ignition/steering column. This is ok unless the actual problem was in the TDM (theft deterrent module) In this case, the 2 wire bypass does nothing. There is another way to bypass this. Check out this link for tons of info and some DO IT YOURSELF options. Ive done several key bypasses and tons of full bypasses. They both work well, it just depends on what part is failing. I think you need the full bypass to eliminate that TDM.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
1994-1999 Eighty-Eight
May 16, 2011 | 1997 Oldsmobile 88
Outside light doesn't work
Hi There, this sodium light needs a higher voltage to work with not the regular one.
Cheers
Nov 09, 2009 | Electronics - Others
Sodium security blinks on and off all night , has replace bulb and works for about a year. then the blinking starts back
is there another light in the vacinity or is the light in question itself pointed at the photocell. most likely scenarios are that the light is pointing at its own photocell so when it is off the photosell senses dark and turns it on but then when light comes on tricks photocell into thinking it is daylight,check position of photocell and adjust away from light source if problem persist could be ballast going bad
Oct 01, 2009 | Leviton 8599 GFCI Receptacle
Need a wiring diagram to connect a photocell to LS 70 sodium fixture
please give me wiring diagram to connet photocel with auto and manual switch
Sep 26, 2009 | Cooper Wiring Devices 1301-7LTWBOX LIGHTED...
Security light goes off and on
if it is a gas bulb (mercury vapor, metal halide, or high pressure sodium) the bulb needs to be replaced. they "cycle" when they go bad for a few weeks then completely stop working
Apr 08, 2009 | Leviton 8599 GFCI Receptacle
Leviton 8599 GFCI Receptacle Logo
1,021 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
