Question about Dryers
No heat, tumbles fine. igniter maybe? and easiest way to get to it?
  • 986 Answers
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Sep 12, 2009
Tumbles but no heat, how do i check out the igniter?
Some dryers have an access panel below the door. If there is a panel and you can remove it, you will be able to observe the igniter. Turn on the dryer so it begins tumbling and demands heat. A good igniter will glow long enough to heat the thermocouple and turn on the gas valve (click). Igniters are rather delicate and can crack with age but newer ones are less likely to do this.
Apr 23, 2016 | Dryers
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
Tip
video section
on May 10, 2010 | Abbaka White Knight 44AW Electric Dryer
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
Tip
on May 10, 2010 | SNK Knight 43AW Electric Dryer
White knight tumble dryer not drying clothes. element is still hot. what is the problem?
Mar 23, 2010 | Whirlpool Dryers
My kenmore dryer modle # 9758920 tumbles but won't
ther is heat fuse on the fan unit and the heat unit check them and then you good :)...take power off first!!!
Dec 31, 2009 | Whirlpool LER5636P Electric Dryer
WHITE kNIGHT tUMBLE DRIER THAT STILL TUMBLES WITH NO HEAT
there is an overheat resettable stat on the back under a small red cover. try for a start pressing the centre of the red cover and you should hear a click and dryer will then heat. this is the most common fault - get back to me if somethinbg different
Sep 05, 2008 | Dryers
Dryers Logo
Top Dryers Experts
