Question about Comfort-Aire BHD-301 Dehumidifier
My comfort-aire dehumidifier #BHD-301 just stopped working. Any suggestions? Should I be doing some kind of regular maintainence?
  • Comfort-Aire Master
  • 43,501 Answers
There are many reasons for a dehumidifierMy comfort-aire dehumidifier #BHD-301 just stopped - 2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 18, 2010
What do the control knob numbers mean. Does the lower the number mean less humidity?
If you have an analog unit the humidity extraction knob should be turned to Maximum.
If you have an LED screen, the arrow down button is what determines the amount of humidity to be removed and maintained. In this case, the lower the number does mean less humidity.
On an analog unit, it's the higher numbers that determine the lower humidity levels.
I hope this helps you and thanks for choosing FixYa.
Aug 16, 2011 | Comfort-Aire BHD-301 Dehumidifier
Ihave a comfort aire BHD-301. when i turn it on the filter lite keeps blinking and the filter is clean. is there another filter besides the one on the side?
No, there's only one filter. So be sure that you reinstalled the filter properly, so that it is making contact with the filter switch. If that checks out OK, turn the unit OFF & unplug it for 15 minutes.
After the time has elapsed plug the unit in and turn it ON. Hopefully, during that timeout, the electronics reset and reverted back to the original factory settings, If so, you can now set the controls as you desire.
I hope this helped you and thanks for choosing FixYa.
Jul 24, 2011 | Comfort-Aire BHD-301 Dehumidifier
I have a comfort air dehumidifier that does seem too effective. also theer is a tube on top of the water bucket? whats that for?
That's the water collection tube, that drains water into the bucket. What's the other other problem that makes it seem, that the dehumidifier is not to effective?
Jun 01, 2011 | Comfort-Aire BHD-301 Dehumidifier
Humidifier gets ice on top of cabinate. It still produces water.
Most dehumidifiers have a defrost cycle that they run through, as needed. But, apparently, your is not functioning. Eventually, yours will stop collecting moisture, if this continues. In the interim, I would suggest turning the Master OnN/OFF Switch to OFF and unplug the unit until it thaws. While it's unplugged, remove and clean the air intake filter on the front of the unit. If it's clogged it causes the unit to strain and may cause it to ice up. Once the filter is clean and the unit is un-thawed. Plug the unit back in and turn the Master ON/OFF Switch to ON and set the controls as you normally do. Hopefully, that period of being unplugged will have allowed the unit to reset itself and work properly.
I have included a link to your Owners Manual that you can download and print for future reference.
aire.com/index.php?option=com_rubberdoc&view=doc&id=436&format=raw">http://www.comfort-
If the above link fails go to the following link below and click on Owner Manual, near the top of the page.
aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g">http://www.comfort-aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g
Hope this helps you solve the problem.
Apr 27, 2011 | Comfort-Aire BHD-301 Dehumidifier
Display says to check filter runs but barely collects any water
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Apr 16, 2011 | Comfort-Aire BHD-301 Dehumidifier
I have a Comfort-Aire BHD-301 dehumidifier that runs but does not collect water. What should I do?
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Aug 09, 2010 | Comfort-Aire BHD-301 Dehumidifier
Good morning--my Comfort Aire dehumidifier will no longer run & is still under warranty. When I turn it on the red light just comes on.
May be power supply failure, faulty control panel or other problem. It may just need to be left unplugged overnight for reset.
Aug 27, 2009 | Comfort-Aire BHD-301 Dehumidifier
No power
check the plug on the unit could be bad or bad cord
Jun 20, 2009 | Comfort-Aire BHD-301 Dehumidifier
Dehumidifier icing up
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Aug 29, 2008 | Comfort-Aire BHD-301 Dehumidifier
Comfort-Aire BHD-301 Dehumidifier Logo
503 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Mike Squire
Bill Long
Michael Youngman
Michael Youngman
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
