Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
Raypak 2100 Light flickering and clicking
I have RP 2100, was working fine, now when I press the on switch, light flickers and clicking can be heard, not the same clicking as before. making access to the panel, the clicking is coming off of the cir. board. Could it be the board or another problem?
  • 990 Answers
If sound of click has changed try this; Get a small mirror that you can use to inspect in the burner tray while trying to start and inspect after dark to see if the spark is jumping anywhere it should not. Also when it is light out do the same only look closley at the pilot assembly itself and see if any soot has built up on the pilot burner this will also stop the spark from being hot enough to ignight the flame. Be sure to let any gas fumes clear each time you try light the heater as when they build up they can be very dangerious, this is also why you should use the mirror to inspect. To keep your face away from any flair ups.
Posted on Nov 21, 2009
ROL keep displaying on my raypak rp 2100
check gas pressure if too low it will overheat replace rollout fusible link if it happens again you might need a vent stack
Jun 23, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
On a 2004 Lincoln Navigator. Where is the suspension compressor relay located. My vehicle was working fine. After I stopped to get something to eat, as I turn my vehicle On the lights flickered and the air...
Okay the switch is in the back trunk area(I know it a SUV) in the back where you access the jacking tool youll see the switch make sure its on. Now some Navigator some have a shrader valve to pump up the suspension on the front area on driver side. As for the relay you might have to use a enhance scan tool to command it.By the way do you have a misfire?because if there is a misfire it will not inflate or a ABS light on? thse will also cause the suspension to not inflate
Apr 23, 2011 | 2004 Lincoln Navigator
I have a Raypak RP 2100 R405 pool heater. When I
Yes its faulty PC board.As no Power Coming from the board.Click this link directly to get PC board. http://www.a1poolparts.com/-strse-Heaters--dsh--Parts-cln-Raypak/searchpath/1015892/start/61/total/103/Categories.bok ------------------ To confirm the fault in PC board. Check for exact 24 volts on PC board. One yellow and One Blue wire. --------- For checking transformer check 120/240 volt to transformer(time clock circuit breaker wire connections). Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 10, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Sep 16, 2009 | Raypak Pool & Spa
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
328 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
