Question about Garden
I NEED A NEW DECOMPRESSION VALVE FOR MY CALIFORNIA CHAIN SAW
  • 1 more comment
  • alankeenano Sep 14, 2009
    MY CHAIN SAW IS A MCCULLOCH CALIFORNIA S/N 02-012344 &THE TOP OF THE DECOMPRESSION VALVE HAS COME OFF, IV,E TRIED GLUEING IT BACK ON BUT JUST KEEPS COMING OFF, THANKS.ALAN KEENAN.
  • dontbother10
    dontbother10 May 11, 2010
    There are about 15 different active manufacturers for chainsaws; each with 5-20 models. Can you be a little more specific? Manufacturer? Model and serial numbers from the makers tag. Lou
  • Ronald Park
    Ronald Park May 11, 2010
    Need make, model and size to assist you properly.
    President:
  • 2,220 Answers
Posted by dontbother10 on Sep 12, 2009 There are about 15 different active manufacturers for chainsaws; each with 5-20 models. Can you be a little more specific? Manufacturer? Model and serial numbers from the makers tag. Lou
Posted by RonPark on Sep 12, 2009 Need make, model and size to assist you properly.
You must help us if we are to help you!!!
Posted on Sep 13, 2009
Testimonial: "thanks for all your time & help ,alan."
  • dontbother10
    dontbother10 Sep 14, 2009
    You still didn't provide a model number. The name "California" is a marketing gimmick and doesn't help when trying to find a IPL. Current model McCullochs can be found here:
    http://www.poulanpro.com/node4027.aspx
    Click "Products"; "Download manuals";
    1. Click (check) "Illustrated Parts Lists (IPL)"
    2. Click (unchecked) "Operators Manuals (OM)"
    3. Change "Select brand" to McCulloch; leave "Type your search query (i.e. product name)" blank and click "Search" - your saw should be on the list that follows. An inspection of your saw will almost certainly find a matching number.
    4. When you find the correct IPL I suggest you print a copy and put it away for future reference.
    McCulloch can also be reached @ 1 (800) 521-8559. If you go this route please have your saw in hand when you call. It will make it easier for both of you.
    I've invested quite a bit of time trying to solve your question. Please invest some of your own by rating my answer. GL
    Lou
Where is the decompression valve for stihl chain saw 026?
If it has one, it will be directly in front of the spark plug. Most 026 saws did not have one, however, an 026 Pro did.
Mar 14, 2017 | Stihl Garden
Where is the decompression switch on a 075 stihl chain saw ?
If your unit is equipped with a decompression or it will be on the top of your saw. a little black button that you pull up or push down
Oct 15, 2014 | Stihl Chain Saw 051 075 088 090 +
Need thread size for Husqvarna decompresion valve
dont know off the top of my head however you can get a thread identifier tool for 5 bucks, or if you have a tap and die set you can see which one fits then read the number off the side
Dec 17, 2013 | Husqvarna Chain Saw Models 51, 55
Saw starter pulling too hard to start.
Check piston rings. Sounds like you have a seized engine.
Feb 20, 2013 | Husqvarna Chain Saw Models 51, 55
Husqvarna 345 decompression valve
The345 should have a blue push in deco valve on the r/h side of the cylinder, if not there may be a 13mm blanking screw there, this can be removed and a deco valve fitted.
Dec 24, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Put new decompression valve in , when pulling the pullcord there's no compression ,it justs jams
Check to make sure the old valve didn't have part of it fall down on top of the piston. I just had that exact thing happen to a TS400 in my shop for service.
Jul 12, 2011 | Stihl Ts 410 420 Cut Off Saw...
I have been trying to turn on my chain saw. Ive pulled the handle back by the trigger gave a few pull on the rope. then i pushed the button in on the side also the push the button back in by the trigger...
The chainbrake should be activated when starting the chain saw. Activate the chain brakeby pushing the front hand guard forwards.b>Cold engine Start position, 1: Set the start/stop switch in the choke position by pulling thered control outward - upward.Decompression valve: Press the valve to reduce the pressure in the cylinder and makestarting easier. Once the machine has started the valve will automaticallyreturn to its original setting.Air purge: Press the air purge diaphragm repeatedly until fuel fills thediaphragm (at least 6 times). The diaphragm need not be completely filled.Grip the front handle with yourleft hand. Hold the chain saw on the ground by placing your right foot throughthe rear handle.Pull the starter handle, 4: Pull the starter handle with your right hand and pull out thestarter cord slowly until you feel a resistance (as the starter pawls engage)then pull firmly and rapidly until the engine fires.Push down the red choke control: As soon as the engine fires which can be heard through a"puff" sound, push down on the red choke control.Pull the starter handle (6): Keep on pulling the cord powerfully until the engine starts.
Nov 18, 2010 | Husqvarna 450 e-series 18" Chain Saw
I have been trying to make it start but the pulley is too hard. It is a new chain saw.
I think you ran it with oil mixed in the fuel. Did you?
Determine if the warranty is active first. Most warranties are effective for 1 to 5 years. If yes return it to where it was purchased or find an authorized repair facility. A written diagnosis by a good independent saw shop ($10-20) might be a good idea at this point. It is difficult to argue repair charges with an authorized repair facility without some documentation in your favor.
· Remove the starter housing. Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if no repair starter.
· Is the saw equipped with a decompression valve? Yes continue, no proceed with 3.
· Leave the ignition off, set the valve and pull the starter.
· Pull gently to release the valve. Is there a difference in the effort required? If yes continue with 3, if no repair or replace the decompression valve.
· Was this saw perhaps operated without oil mixed with the fuel?
· Remove the spark plug wire and plug.
· Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
· The last likely possibility is the saw has jumped timing. This problem or any not discussed is usually beyond the ability of the operator to repair. Please take it to a good local saw seller/mechanic for a written diagnosis before authorizing any repair. HTH
Lou
Oct 30, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How to adjust chain bar oiler
The Stihl 026 PRO does have an adjustable oiler and it is located on the bottom of the saw just below the clutch drum.
Stihl also builds an 026 "Standard" without the adjustable oiler, however, the hole location for adjustment is still there.
The 026 PRO will also have a decompression valve on top of the saw to make the rope easier to pull during startup. If you have the DECO valve you should also have the adjustable oiler. Hope this helps.
Sep 26, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Decompression valve for Homeliye XL-700 chain saw.
With the age of the chainsaw and the scarity of available parts, it would be major undertaking to even attempt to install a decomp valve into this chainsaw and the result could end up ruining the saw for good.
If I might make a suggestion that you either sell this, as there are many collectors of classic chainsaws such as the XL-700 and you might do better with a newer saw that is easier to start and use.
Either that, or just accept that starting these older saws are more difficult.
As to the C.U. rating for this saw, it is a 4.7 Cu. Inch displacement.
Here's an online manual wih a parts breakdown and exploded line drawings for the XL-700, in case you want to tinker with the saw.
http://www.scribd.com/doc/7283163/Homelite-Xl-700-Xl-800-Ipl
Hope you found this Very Helpful - Best regards!
Aug 18, 2009 | Garden
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
