Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
Bosch Nexxt 500 Series Front Loading Washer
I love my Bosch washer with one exception, the beeping signal that occurs when the wash cycle is completed. Does anyone know how I can disable this?I
I have a nexxt dlx and to turn off the "acoustic signal" - select any program, lets say cotton white, then choose any TWO options hold both until a short signal is emitted, this of from the manuel and I use it
Posted on Mar 15, 2012
    President:
  • 1,653 Answers
The only way is to disonnect the device from the controller board.
Posted on Sep 12, 2009
Bosch Nexxt 100 washer will not fill with water.
Does the problem occur on both hot and cold washes. If not then check the inlet solenoid . If yes than check the board.
Jan 25, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
How do i get the beep at the end of the cycle to turn off
To disable the end of cycle beep on the Nexxt washer, select a program and press two of the option buttons (e.g. Stain Removal and Allergy Rinse) and hold until you hear a short beep.
Aug 17, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Jan 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch front loading washer nexxt 500 won't pump out water on the spin cycle
could be drain hose is not high enough. I had the same problem and when I raised the hose it worked fine.
Dec 04, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Oct 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Acoustic signal
select a cycle. hold down two option buttonsat same time until you hear ashort signal this disable it. (bleach& rinse pluse) to activate do same
Jul 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
963 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
