I have a Lennox heating and air system. It's 5 years old. The tape that hold those long tube things together has failed and the tubes are disconnected from the vents that blow air into the house. I have used duct tape as a temporary fix. I'm told that when winter comes that my duct tape will come apart. Where can I buy the right tape to put everything back together? I have tried to get contractors to do the work, but so far they are all booked up for weeks. My electric bill is sky high probably because I have not used the right tape to begin with. Any help is appreciated.
  • sunny494 Sep 12, 2009
    Yes, the whole system installation and workmanship is lousy. Nothing but problems. The tube things aren't even the right size and weren't even ran right according to another contractor. But that's another story.
    Regarding the flex ducts, these ducts are shiney like alluminum foil and are strapped to beams in places throughout my basement (it's a huge basement). So should I pull back the alluminum looking wrapping and tape under that. Originally the tape was on the outside and visible.
    Your help is appreciated.
  • 34 Answers
Sounds like a lousy job. Best tape is alluminum. You can pick it up at Home Depot or Lowes. If the tubes are flex duct be sure to pull back the outer insulation and tape just the inner lining
Posted on Sep 12, 2009
  • John Pappano Sep 13, 2009
    Depends on what kind of duct it is. If it's steel solid round duct it would have to be screwed together. If it's flex duct it will have foil or plastic outer cover and thin layer of insulation and more plastic on the inside of duct. The inner plastic must be taped to the collar of the main duct. Hope this helps.
Speaker wire sheath has split
There are a number of items you could use to cover (repair) the exposed wire. I agree the quickest repair would be to use electrical tape, everyone has it at home but I don't find it very durable. The easiest, most durable, waterproof, and coolest solution would be to use Bondic
Bondic The World First Liquid Plastic Welder Not Glue
I found it the other week at my Redmond's Home Hardware store and I keep finding things to use it on. It has a precise applicator and the flow of material is very controlled so it allows for very tidy repairs.
You could also use liquid electrical tape, it's messier but it will stick better than regular electrical tape
Apr 08, 2014 | X-1 x Interval 4G Waterproof Headphone...
My Whirlpool LER4634J Electric Dryer heats up some, but doesn't dry clothes
Your problem sounds like it could be the thermostat/thermistor.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.Reassemble the air tube and plug back in the dryer.Turn on the dryer.
If the heater coil get red and very hot, then you will have to replace the thermostat/thermistor because they are falulty.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 15, 2009 | Whirlpool LER4634J Electric Dryer
Dryer runs but no heat
Sounds like your problem may be with the heating coil.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
You can also check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
Good Luck,
Hope this helps
Oct 14, 2009 | Whirlpool Dryers
Dryer won't heat. GE profile. approximately 5 years old. Tumbles just fine. Vent is not plugged. Would like to fix myself. Thanks
Good Luck,
Hope this helps
Oct 14, 2009 | GE Profile Harmony DPGT750EC Electric...
Turns one but does not heat up to dry
Good Luck,
Hope this helps
Oct 13, 2009 | Hotpoint Dryers
My heater isnt working on my Proline TDC7A tumble dryer I know there are 2 thermal cutout switches which may either need resetting or renewing but where do i find them ?
Good Luck,
Hope this helps
Oct 13, 2009 | Dryers
Doesn't heat up
If the heating coil is ok, then:
Good Luck,
Hope this helps
Oct 13, 2009 | Kenmore Dryers
I have a Whirlpool model LER8648LW0 that is about 8 years old. It gets a lot of use. It used to dry well, but now takes almost twice as long to dry an average load. Towels take about 1 1/2 hours on high...
If the coil is ok, then you want to check the thermistor/thermostats. Remove the wires and tape them together one at a time with electrical tape and turn on the machine and see if it heats up ok...if it does then replace the thermostat/thermistor that is bad.
DO NOT LEAVE THEM TAPED TOGETHER. BECAUSE THIS BY-PASSES THE SAFETY OF THE MACHINE.
Good Luck,
Hope this helps
Oct 13, 2009 | Whirlpool LER5636P Electric Dryer
Our dryer will not not heat up to its full heating potential anymore.
You should also check the thermostats/thermistor, you can remove the wires from them one at a time and tape them together using electrical tape, then check the heat. If it heats properly, replace the thermostats/thermistor that is faulty.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER YOUR TEST! This could cause a fire
Good Luck,
Hope this help
Oct 09, 2009 | GE Dryers
Furnace will not heat.
Most of the Lennox G-16s that I have repaired were having problems with the gray Penn-Johnson Piggyback igniton control module.
This is best repaired by replacing the spark module. Sometimes it may be neccesary to replace the gas valve also. Lennox updated to a ROBERTSHAW ignition system. Honeywell can also be used.
Also check that there is no water in the pressure switch or tube.
Hope this helps.
Matt
machtcl1@verizon.net
Jan 13, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
