Question about Mitsubishi WS-55809 55" Rear Projection Television
Sometimes it takes a minute to get Reception
When I first turn it on Sometimes it takes a minute to get Reception and then it will stay on for about minute then no Reception then it will be fine.
Weird.
  • 1 more comment
  • Racerxedge Dec 11, 2007
    I can't get into the " Service Menu ". I tried a bunch of different ways with no luck.
    I got in and tried but it didn't make any difference. Any other Ideas ?
    I tried Solution # 1 but it didn't make any difference.
    When I 1st turn the TV on Sometimes it takes a Minute to get a signal,
    Then Sometimes it says on and other times it will loose the signal and
    then come on again.
    Genius:
  • 1,153 Answers
White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change
Posted on Dec 11, 2007
How do you set an atomic clock
You're not supposed to set the time -- it's supposed to synchronize with the US atomic clock broadcast automatically. Perhaps putting it in a different area of the house, or turning it to a different orientation will help it make the initial connection.
If it still won't, here are instructions from one of the LaCrosse models... use them or go to http://www.lacrossetechnology.com/clocks/atomic-digital/wall/
and find your particular clock, then download the instructions.
MANUAL TIME SETTING
In case the atomic clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock. Note: In 12 hours mode the time will be displayed with an additional "PM" for the time from 12:00 noon until 11:59.
1. The hour digits will start flashing on LCD1.
2. Set the desired hours by pressing and releasing the + key followed by pressing the SET key.
3. Now the minute digits will start flashing.
4. Set the desired minutes by pressing and releasing the + key . If the + key is held, the units will increase by 5.
5. Press and release the SET key to move to the "Year Setting".
Note:
The unit will still try and receive the signal every day despite it being manually set. When it does receive the signal, it will change the manually set time into the received time. During reception attempts the WWVB tower icon will flash. If reception has been unsuccessful, then the WWVB tower icon will not appear but reception will still be attempted the next hour.
WWVB reception occurs daily at 12:00 am and 06:00 am. If the reception is not successful at 12:00 am, then the next reception takes place the next hour and so on until 06:00am, or until the reception is successful. If the reception is not successful at 06:00 am, then the next attempt will take place the next day at 12:00 am.
The other times WWVB reception takes place are upon setup and after manual time set exiting mode. Reception is generally not possible during daylight hours due to the interference of the sun.
Jul 28, 2014 | La Crosse LaCrosse Atomic Digital Wall...
I cant listen to the radio but cd will play. I know the radio works but only for a few minutes.
When you put the tape in and play your songs,then take it out or eject the tape, push in the radio mode, you should the radio , if not check to make sure you got a good antenna connection, sometimes there maybe a delay but hopefully not two minutes, should be more like 5-10 second delay
May 05, 2012 | 2005 Ford Freestyle
TV won't stay on for more than 10 minutes. Won't turn on at all s
Sounds like a power supply issue. Is it out of warranty? If it is, open it up and check the power supply bd. for swollen capacitors....
Apr 07, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
On a hot day the radio reception will stay clear for only a few m
It is the overriding by intersteller priority dimensional language conversion filtering. Nothing to worry about, It can be easily defeated and modulated by tightening your removable Radio Antenae.:-) Good Luck_Ned_
Oct 19, 2009 | 2002 Volkswagen Jetta TDI
MY TOMTOM ONE IS WAITING FOR A VALID GPS SIGNAL I HAVE ALREDY STARTED TWICES
Turn on your tt and let it bootup. After it has booted up go to the map screen. On the bottom right where the bars are for satellite reception. Tap the bars this will take you to the screen telling you the device code etc. On the upper far right where the battery icon is tap the screen again. This will take you to a screen showing the satellites. If you see grey bars on the graph just wait awhile. Sometimes when your tt has not been turned on for awhile or you have turned it on after traveling a few miles it may take up to 30 minutes to get a lock.
Hope this helps
May 06, 2009 | Tomtom ONE GPS Receiver
Loses reception
Is it a water damaged phone or dropped?
May 19, 2008 | Motorola Mobility RAZR V3
Mitsubishi (2001 ?) 60 inch projection TV Model VS-60609. DVDs and video games work perfectly but NO tv reception- we have Comcast. I've plugged cable into every possible hole on the TV- no luck. THX!
My mitsubishi 2001 tv model 60609 plays sometimes for a couple of minutes and then turns off; but you can still hear the volume and if you try to turn it back on it will turn right back off.
please help me!
Apr 23, 2008 | Televison & Video
Mitsubishi WS-55809 55 inCH tv
best way i would trouble shoot this would be to get a can of freeze from radio shack and spay the tuner if the problem comes back you know it's the tuner if not spray IC one at a time till the problem happens.
Dec 11, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Poor satellite reception
the cheap way to fix it is to make an extended antenna
if you look in the back youll see a gold circle that is made to add an external antenna. now get some foil twist a small strand and push it in the back of the nuvi untill it hits the gold ring. just add some scotch tape to hold it and it should be good
Oct 20, 2007 | Garmin Nuvi 660 GPS Receiver
AM reception/AM power problems
Don't take your radio to work. Get your work done , then go home and listen to it. You will get better reception in a res. area.
Oct 08, 2007 | RCA RP7887 High-Performance Super Radio
Mitsubishi WS-55809 55" Rear Projection Television Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
