When i try to downlaod software off the internet it asks me what program i want to put it under, and when i try to access my windows files i get a system 32 error(rundll32) application not found
    President:
  • 2,600 Answers
First, make a new folder on your desktop and name it Temp Download or something like that. When you download a file, look in the left side of the window and click on desktop, then scroll down for your folder you made and hit ok. Don't worry about renaming the file and don't worry about what it is saving the file as....doesn't matter right now...small steps first. Also when downloading be aware of a small pop up bar that appears sometimes over the browser window that states that the download has been stopped until you give the ok. If you continue to get system 32 errors, a repair of the operating system may be in order.
Posted on Sep 12, 2009
Do you know any BKF file recovery software?
You can try to use RecoveryFix for BKF recovery software to restore your deleted file. For more details you can downlaod this software: http://www.bkfrestore.org/download-free.html
http://msbkfrecovery.blogspot.com/2012/08/get-access-to-your-corrupt-or-damaged.html
Apr 07, 2014 | Computers & Internet
I purchased a webcam found webcamMax. When I downloaded the program a search program appeared called ASK as windows internet explorer program. I did have google, but now when I go to internet explorer it...
In order for you to remove that ask software that was install on your computer follow this steps:
Go to this link first and download and save the file to your computer.
http://media.ask.com/media/toolbar/tools/AskSearchUtility.exe
Then after that run that software to remove the ask software from your system.
If you want to double check , you can also look under control panel under programs and look for Ask software if its there remove it.
May 05, 2010 | Computers & Internet
I have a toshiba tecra m3.i tried to install windows xp media center edition????with no joy! it keeps saying install disk 2 when i install disk 2 nothing happens , i have windows on the laptop but nothing...
First you have to know if that Windows XP Media Center is compatible with your laptop, it should be properly installed to avoid errors.
Second if you don't have drivers, you have to access the internet so you don't have any choice but to use another computer to download all the drivers for your laptop
Here's the site for your tecra laptop
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=882872&rpn=PTM30U&modelFilter=M3&selCategory=3&selFamily=1073768664
Jan 11, 2010 | Computers & Internet
I try downlaoding n it ask me to save, i save it
By default the files are save to your documents folder.
Regards.
Aug 26, 2009 | Mozilla Firefox
Problems opening links in Outlook 2003
The most common cause is a corrupt registry key in Internet Explorer. The registry key found at
HKEY_Local_Machine\Software\Classes\htmlfile\shell\open\command
is either damaged or corrupt.
To fix it, try resetting Web settings in Internet Explorer. If this does not resolve the issue, set IE as
the default browser.
To Reset Web settings:
Internet Explorer 6
Start Internet Explorer 6.
On the Tools menu, click Internet Options.
Click the Programs tab, and then click the Reset Web Settings button.
Under Internet programs, verify that the correct e-mail program is selected.
Click to select the Internet Explorer should check to see whether it is the default browser check box.
Click Apply, and then click OK.
You may receive the following message when Internet Explorer starts:
Internet Explorer is not currently your default browser. Would you like to make it your default browser?
If you receive the message, click Yes.
Internet Explorer 7
Start Internet Explorer 7.
Click the Advanced tab, and then click Reset.
Click the Programs tab, and then click Set programs.
Click Set Default Programs.
Click to select Microsoft Outlook, and then click Set this program as default.
Click OK, and then close the Default Programs dialog box.
In the Internet Options dialog box, click the Programs tab, and then click Make default under Default web browser.
Click OK.
Back to the top
Export and import the registry key from another computer
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
Note Use this method only if the earlier instructions for each browser do not work to resolve this problem.
Export the registry key from another computer
Click Start, and then click Run.
In the Open box, type regedit, and then click OK.
Locate the following registry key: HKEY_Local_Machine\Software\Classes\htmlfile\shell\open\command
Click the command folder.
On the File or Registry menu (depending on your operating system), click Export.
Note the location of where the file will be saved. The registry file can be saved directly to the hard drive or floppy disk.
Type a unique file name, and then click Save.
Quit the Registry Editor.
Import the registry key
Copy the Exported registry key to the desktop on the problem computer.
Double-click the .reg file.
You receive the following message:
Are you sure you want to add the information in drive: location file was copied to\file name.reg to the registry?
Click Yes, and then click OK
Jul 27, 2009 | Microsoft Outlook 2003 for PC
Downloading - I do not know how to do this, is there a manuel?
Its very simple..I guess you downloaded the Win XP torrent file.. Now Click on the below link adn you will downlaod a software called "utorrent" - which ccan be used for downlaoding the torrent files.
http://download.utorrent.com/1.8.2/utorrent.exe
After downloading..just insatll it and all .torrent files will open in this program..as soon as it open, it wil start downloading the Win XP.
Thank you!
Mar 28, 2009 | Computers & Internet
New Computer bought this morning upgrade to Vista Ultimate now nothing on computer
u can try using the recovery softwares to get back ur files,
but, till u do tat, u dont add any file to tat drive, cause,if u do so, ur old files will be overwritten.
try this link for tat software
http://www.recovermyfiles.com/?file=RecoverMyFiles-Setup.exe
Jul 20, 2008 | HP Computers & Internet
NET Framework and msvcr80.dll programs
The msvcr80.dll is required for the software developed under microsoft C++. And if the microsoft visual C++ is not installed on that machine this raise error.
It sounds you are facing same problem, if then downlaod microsoft visual C++ redistributable package and install it on your machine. I think it will fix your problem.
Click here to download
Thanks
Iqbal
Mar 16, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
David Payne
David Payne
