Question about Brother MFC 210C All-In-One InkJet Printer
Keeps saying can't print, and balck in is near empty. Changed black in several times and with new cartridges. Still keeps saying can't print and refer to maual. Manual does not give further info.
Just had new printer again kodak esp 7 and got same problem black ink cartridge not printing
are the ink cartridge you are using refurbished because sometimes the printer wont read them had a simular prob with my printer you might have to just buy new ones for it
Sep 30, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
HP LaserJet 2600N All colors are empty, but Black is brand new. It still says Replace Supplies and the light keeps flashing. Oh, and it won't print anything. So even if I want just B&W, do...
None of the cartridges can be empty if you want to print.
Even if you only want to print black, just black you need to
replace the other three cartridges.
Yes color laser printing is expensive.
Jul 14, 2011 | HP Color LaserJet 2600n Printer
My colored cartidge is out and my black is full. I went in under maintenance and changed it to balck only and printer preferences and changed it to grey scale. it still wont print black only
Some printers simply will not work if one of the cartridges is empty, even if you are not printing with the cartridge. The other catch might be is that some printers create grey scale by mixing colors so you might want to turn off grey scale and try printing just black and white.
Apr 13, 2011 | Computers & Internet
My printer comes up with an error saying I need to slide the green tab in the drum/cartridge back and forth several times and return the green tab back to where it belongs. I have done this several times...
Moving the GREEN TAB moves the toner-ink inside the cartridge, to more uniformly spread it.
Since the toner-cartridge is nearly empty, you probably need to replace the toner-cartridge with a "full" one.
Nov 17, 2010 | Brother HL 2140 Laser Printer
I have replaced all the ink cartridges and my printer says "no cartridge, open scanner cover"
It is probably best to replace cartridges individually as necessary. Let me explain. The printer display will tell you when a cartridge is "xx near empty" and when "xx empty" (where xx is the cartridge color).
1) Near Empty - you can continue to print. This message is to remind you to get a new "xx" cartridge and have it on hand.
Replacing the cartridge when "Near empty" will cause the machine to report "xx Empty" when it is not. It will not register that you have replaced it at "Near empty." Wait to replace the cartridge when you get the "xx empty" message.
2) XX Empty - you may not be able to continue printing. Replace cartridge "xx" now per your manual.
If you have replaced or reseated more than one cartridge, and you get the "no cartridge" error, you need to find out which one the machine "thinks" is problematic:
1) With the scanner cover open and locked in the "Up" position, the message may change to "Change cartridge, install xx" (xx refers to the color )
2) After changing the suspected cartridge and closing the scanner cover, be sure to notice the display. It will say, "Changed XX? 1. Yes 2. No" Press 1.
If all this explanation does not work, keep it in mind for next time. Brother says to unplug the machine for at least 10 seconds, then plug it in again. If the display shows the date and time, problem solved. If not, you may need to contact brother support.
Jan 22, 2010 | Brother MFC 420CN All-In-One InkJet...
No printing
hi,
Check your black ink cartidge. it may be empty.change it with new balck cartridge
this problem may also be due to cartidge holder .
clean cartrideg holder with moist cotton with petrol or some other cleaning liquid as nail polish remover. clean properly the cartirdge socket and mainly the contact point of cartridge socket
Aug 20, 2009 | Lexmark X3650 Printer
New Cartridge - Black showing no ink
u check ur head is working properly i think this main error of head where u insert balck vartrige if u have same printer then u have check replace the black cartrige find out it work properly then sure ur balck head is damage
Nov 04, 2008 | HP Business Inkjet 1000 - Printer - colour...
Printing in grayscale
yes u can use it with black and white
Nov 01, 2008 | Dell 3010cn Laser Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Brother MFC 210C All-in-One Ink Cartridges
near empty message is a reminder: plz buy a new cart (but do NOT change until EMPTY). You still can print.
the ink left in an empty cart keeps the system alive when some ink is neede for the automatic cleaning cycle.
If you print until this cart is really empty air will get into the tubes and ph. That leads to faulty printings.
brother had made sure that the amount of printable ink can be consumed. The rest is for service.
Jan 31, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
48 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
