Question about Dell 3130cn Color Laser Printer
Getting an error message on my dell 3130cn printer that says remove tape from C cartridge. I did remove tape and even put in a second new cartridge with same error
Error code 093-921
If you are seeing any or all of these error codes on the Dell 3130cn Laser Pinter that there is a Firmware Update to address this issue. However, the firmware cannot be applied when there is an error present, so first try reseating all toners. You may need to repeat this several times before errors are cleared. Once error-free, download the Firmware from the Dell Support website and apply.
Reset the Cyan toner properly.
Follow
TapeOn a cart... Cart Error 093-919, 093-920, 093-921, 093-922 on a Dell Color Laser Printer 3110cn 3115cn 3130cn tape POST Laser Printer 3110cn 3115cn 3130cn
  1. Verify all packaging has been removed from the printer cartridge. This includes any tape or red handles. Also verify the toner cartridge is properly installed.
  2. Remove the toner cartridge and clean the toner housing of any excess toner with a clean dry cloth. Reseat the toner cartridge when finished cleaning.
  3. Check that all toners are Dell branded and not refills. Take note of all PPIDs (Serial Numbers). Check that all toners are for the correct model
    • If any toners are non Dell, swap with another toner
  4. Run diagnostics on the toner cartridge sensor.
    1. Power off the printer.
    2. Hold down the and buttons on the printer and power the printer on.
    3. Release your fingers from the keys when the message Diagnosing... appears.
      Customer Mode and ESS Diag display.
    4. Press the button until IOT Diag appears and press the button.
      On the LCD, Digital Input appears.
    5. Press the button until Digital Input appears and press the button.
    6. Press the or button until DI-8 for (yellow) DI-9 for (Magenta) DI-b for (Cyan) and DI-a for (Black) appears and press the button twice. It is only necessary to run the diagnostic on the toner cartridge to which the error applies
    7. Open the front cover. (Figure 1)
      Figure 1 - Open the Front Cover
    8. Remove and replace the toner cartridge. Every time the toner cartridge is reseated, the counter on the Operator Panel will increase by 1.
      • If the diagnostic does not increase by 1 then replace the toner cartridge.
      • If the diagnostic does increase by 1 and the error persists, Please contact Dell Technical Support for further advice.
Knowledge Base
Mar 02, 2016 | Dell 3130cn Color Laser Printer
Tip
How To Remove 077-100 Error in Dell 3130cn Printer?
This is right that error 077-100 error is belong to Registration and or Exit sensor.
But if the yellow toner cartridge doesn't run so there will jamming the paper and the printer shows the error (077-100).
Actually i solve the issue after three days when i guessed and checked the yellow toner cartridge it was tighter than others.
So i replaced the yellow toner cartridge and solved the issue.
on Mar 29, 2016 | Dell 3130cn Color Laser Printer
The magenta isn't printing correctly, and the printer keeps telling me to remove tape from the magenta cartridge. There isn't any tape on it. I've tried resetting it several times.
Its sounds as though the printer isnt picking up the cartridges properly, try removing it and cleaning the contacts on both the cartridge and the printer
May 05, 2011 | Dell 3130cn Color Laser Printer
I have a Dell Photo926 printer. I just changed the color ink cartridge and it is giving me an alignment error stating remove tape from cartridge. There is not any tape on the cartridge. I have ran the...
Are you using Dell Series 9 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 9 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 9 color cartridge.
You are using Dell Series 9 ink cartridges, correct?
Dell Series 9 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 9 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
Black cartridge = black side(left side) Color cartridge = color side(right side)
Photo cartridge = black side(left side) Color cartridge = color side(right side)
It is possible to get a Dell Series 9 cartridge with a bad sensor. Contact the place of purchase for a replacement.
Rick
Apr 26, 2011 | Dell 926 All-In-One InkJet Printer
I am getting the following error message: Black/photo cartridge missing
Power on the printer. Open the printer and take out the Dell Series 5 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 5 color cartridge.
Close the printer. It should print an alignment page. Any error messages?
Black cartridge = black side(left side) color cartridge = color side(right side)
Photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
If these ink cartridges are new, then take them to the place of purchase for a refund or replacements. If they're old, then try purchasing a new Dell Series 5 ink cartridge.
Rick
Mar 06, 2011 | Dell 924 All-in-One InkJet Printer
I intalled new ink on my computer and it says to remove tape from cartridge when I all ready did and it will not work
Unplug the printer from the wall. Noe remove the power brick from the printer for 60 seconds. This will reset any error message the printer is getting. Plug the printer back in.
Turn on the printer. Open up the printer and take out the black cartridge and reseat it. Do the same for the color cartridge. Now close the printer and it will print an alignment page. Any error messages?
If you still get the error message, then it's possible that the sensor in the Dell Series 5 ink cartridge is bad. If this is a new Dell Series 5 ink cartridge, then take it back to the place of purchase for a replacement or refund.
black = black side(left) color = color side(right)
photo cartridge = black side(left color = color side(right)
It's possible to purchase a Dell Series 5 ink cartridge with a bad sensor. Please take it back to the place of purchase for a replacement.
Rick
Jan 10, 2011 | Dell 962 Photo All-In-One InkJet Printer
Cartridge alignment problem - it says to remove tape from cartridge or troubleshooting. There is no tape on the cartidges.... HELP!
Rick
Jan 09, 2011 | Dell 926 All-In-One InkJet Printer
Dell 3130cn gone down with repeating 016-370 Error...
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer. Please let me know the results.
Jun 28, 2010 | Dell 3100cn Laser Printer
Dell printer model# A940 50c error
Test your cartridges.
Remove the color ink cartridge then lower the cover of your printer. If the error message displays again, replace the black cartridge with a new one (or return the new one). Reinstall the color cartridge and remove the black ink cartridge then lower the cover. If the error message displays again, replace the color cartridge with a new color cartridge.
Note: My manual indicated that the printer might have detected a short circuit in a cartridge. I returned a month old black cartridge got a new one and my printer is working fine now. Good luck.
Nov 10, 2008 | Dell A940 All-In-One InkJet Printer
Dell 3130cn Color Laser Printer Logo
1,916 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
