Question about Dryers
My whirlpool dryer doesnot produce heat so have to run it for 2-3 times for clothes to dry
  • 986 Answers
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Sep 12, 2009
Why do clothes take a long time to dry even if dryer is heating?
Sounds like there is still a blockage somewhere, maybe near the filter screen.
Jan 22, 2015 | Whirlpool Dryers
Clothes not getting dry
sounds like perhaps you are losing your heating element...could be electronic, but it's most likely the actual element needs to be replaced...
Apr 25, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryer Works but does not produce heat
I would first check to see if 240 volts is coming into the machine. The motor runs on 120 the heater need 240. If that is fine remove the rear panel and check the 2 limits and heater on the right hand side for continuity. Here is my video:
Jan 09, 2014 | Whirlpool Dryers
My whirlpool AWZ510E washer dryer - the dryer doesn't seem to be working - it goes through the cycle but the clothes are still as wet as before. I am using the same cycle as I always have which used to...
there are 3 reasons for a dryer not doing the job yet running through the motions. 1st, the heat is not being produced and only cool room temp air is circulating. this can be a burned-out electric element or an over-heat sensor, or in0line safety fuse. ( if gas, can be ignitor or gas valve coils).. It could be that the washer is not ringing (spinning) dry the clothes verywell and there is too much moisture stiil in clothes which would double the dry time from 50-60 minutes to 2 hours. 3rd, could be clogged vent line and the hot moist air cannot leave the dryer so the clothes get hot by the moisture stays.
Apr 28, 2010 | Whirlpool Washing Machines
Whirlpool dryer not heating
Check the heater element and the 2 thermal fuses for continuety
Mar 06, 2010 | Whirlpool LER4634J Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Gas dryer runs, cleaned hose, get warm does not heat up to dry
with a gas dryer in which your assured te hventing is free and clear of any obstructions, i would look to replace the coil pack located atop the gas valve itself, probably about $25 part number 279834... 2 coils simply mount atop the valvle
Feb 11, 2009 | Whirlpool Dryers
My Dryer has stop producing heat
hi mark it the heating coil in the back of the dryer
Feb 10, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer tumbles but does not dry
the act that there is even a partial heating, bfore i say there may be a problem with the unit, I would ask that you check your venting for possible clogs/blockages. I fhte machine cant vent away the heat the it will not produce more. This is hte MOST common issue with all my dryer repairs. 2x-3x to dry clothes, start with the venting
Dec 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Dryers Logo
43 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
