Have a LG Washing Machine WF-T854A. Is not stopping filling when full and now when its is turned on just beeps and displays error message 6E.
  • shane_higgin Sep 12, 2009
    What part do i need to order to fix the problem. Is the micro processor the main electronic board that runs the machine
    President:
  • 1,462 Answers
6E error means ambient temperature is too low.
A problem that occurs when the potentiometer connected in series with the thermistor on the microprocessor board is damaged.
SInce the microprocessor is damaged, the water is not getting stopped after getting filled...
You should call a repairman or even phone tech support to repair your machine..
As this is under generic problems on all washing machines, due to water getting poured over the circuit board..
RATE THIS SOLUTION!
RNJ VINOD KUMAR
Posted on Sep 12, 2009
  • Vinod Kumar
    Vinod Kumar Sep 13, 2009
    You have to call the service technician and check, ow far the board id damaged...And you have to decide whether to replace the board or the microprocessor
LG WF-T6517TC my washing machine WF-T6517TC when it start to wash get Alarm "dE" beep and stop machine. what need to do
Don't know exactly what that code is but normally washing machines will beep and switch off quickly if the pump is blocked.as it's not allowing water yo be pumped around.
I suggest that is checked firstly before calling anybody out.
Jan 02, 2015 | Washing Machines
Error message - PE.... on lg intello washer. my washer is full of clothes and water.it won`t get to the cycle for rinsing .I press on auto-off , then start-pause . the light for water-level does not go on...
Is there a lot of water inside like more than normal? That is a pressure sensor error. Check pressure hose inside the washer. It is a small hose about 5/16" diameter connected to the tub and pressure switch. If there's a hole in it the air scape and the pressure switch will not turn off the water. The control board detects the problem and stop will show error code.
Nov 21, 2017 | Washing Machines
LG Top Load Washing Machine Model: WF-T7517TE , kg TURBO DELUXE. On Pushing START button , MAchine just starts and stops after a second. Message displays "dE". What to do ?
'de' on LG's stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 20, 2011 | LG Washing Machines
LG washing machine WF-T854a. Spin dry does not appear to be working. machine makes afunny noise
well sounds to me your gonna need a technician could be a rear bearing problem but check lower filter trap first there gonna bee some water uses a bucket and a couple of towels check for obstruction if no obstruction the probably rear bearing and spider assy...
Jan 26, 2011 | LG Washing Machines
STARTED, ROTATED A FEW TIMES, FILLED UP WITH WATER, NEXT MODE "WASH" BEEP BEEP. BEEP BEEP.. "d E" .. MACHINE STOP. POWER STILL ON. CONTROL BUTTONS STILL FUNCTIONING. IT IS A LG...
he error code "dE" signifies a door open error. This may simply be because the door is not all the way closed, though it could also represent a number of other problems. There may be a faulty door switch, a malfunctioning electrical connection or a damaged gasket.
Dec 11, 2010 | Washing Machines
My machine keps stopping and giving a 6E message
Hi
Thanks for using FixYa. Error 6E is a ball sensor error which is displayed due to loose Ball Sensor Connector and/or when the Ball Sensor goes bad/is out of order. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | LG Washing Machines
LG WF T6517TC Washing Machine does not fill water
sir
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
Willnot spin, error code 6e
lg wf-t851 will not spin. displays 6e error code
May 23, 2009 | LG WM-2277HW Front Load Washer
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
