I have a leak at the accumulator on a 2001 Dodge Ram 1500 and I'm trying to get the lines loose, can you tell me the correct way to loosen them and what a/c tools I'll need for the job.
  • 1,250 Answers
Http://www.autozone.com/autozone/ymme/ymmeYear.jsp?_requestid=304737
go to this site and put in your vehicle info. Then filter down to your problem. It has a DIY section that seems pretty good. Check it out.
Hope this helps.
Posted on Sep 12, 2009
2001 Dodge Ram 1500 3.9 V6 Seems not to go into low gear anymore - also, won't kick down into low even at low rpm. Anyone got a fix?
You may have a leak in the vacuum line which tells the tranny to switch gears, or it may have an electrical sensor instead of a vacuum line, Most new trannys are controled by electrical signals from sensors
Nov 01, 2013 | 1999 Dodge Ram
P0455 P0442 codes 2001 dodge ram 1500
P0442 Means you have a small leak in your EVAP system. P0455 is a large leak.
The EVAP system prevents gas vapors from entering the air .
This code can be set by a leak in the lines or a clogged charcoal canister.
Most common reason is If you did not put your gas cap on all the way.
Hope this helps
Leave feedback please
thank you FixYa
Nov 20, 2010 | 2001 Dodge Ram 1500 Truck 2WD
Our 01 1500 Dodge Ram 2WD pickup's air conditioner kicks over to heat every time we break. Is this a vacuum problem?
Yes it is, but where is going to be the fun part. Under the hood on the left side of the engine. "passenger side" right near where the a/c lines go into the truck is a set of vacuum lines. If they trace to the left side of the intake manifold thats them. there is 3-4 joined together that merge into one and plugs into the manifold. Inspect these lines for cracks or a loose fit. The brake booster pulls alot of vacuum so a loose or cracked line is the culprit. I would also be willing to bet that since the a/c dose work, that the leak is under the hood. Hope this helps :)
Jun 28, 2010 | 2001 Dodge Ram 1500 Truck 2WD
P/S 2004 Ram
Without having a picture I couldn't tell you if that's the return line. Actually I would need a book on it. What I would suggest is trying to tighten it just a little. Don't overdo it cause that is easy to do. You can also loosen it and throw some thread tape on it and tighten it back up to see if that works. Good luck!
Jan 09, 2010 | 2004 Dodge Ram 1500
I received the following trouble codes on my 1997 Dodge Ram 1500 with the 5.9 liter engine: 12, 31, 56 I assuime 12 is a toss away... I don't understand the description for 31 and I cannot locate 56 in my...
code 31 is the evap system, the fumes from the tank, the computer can seal or vent the vapors, and so its telling you theres a big leak its not able to seal, could be a loose or bad gas cap or a broken vacuum line for the system or a vent or purge valve went bad,code 56 is not a code, double check . good luck,hope this is helpful.
Dec 19, 2009 | 1997 Dodge Ram 1500 Club Cab
2001 Dodge Ram 1500 4x4 engine light on and code reads P0455 could U please tell me what that means? thanks
Evaporative Emission System Leak Detected (large leak)
Is the gas cap missing or loose?
Dec 01, 2009 | 2001 Dodge Ram 1500 Truck 2WD
I have a 2001 dodge ram 1500 4X4, the truck dies in reverse
I have no idea if this relates to your problem or not but a fairly infrequent problem with Jeeps exists in some models if the transmission bolts loosen. Our son's problem also involved backing up (only; forward=no problem) and having the engine cut out as sometimes die. On a Jeep forum, a poster warned that if the hard-to-reach upper bell housing bolts weren't tightened properly, they would loosen and cause this problem.
Nov 26, 2009 | 2001 Dodge Ram 1500 Truck 2WD
I have a 2001 dodge ram with a 5.2 liter 318 engine. i checked my code & it came up as #P 0455. the problem i am having is when you first touch the gas, it has just a little bit of hesitation &...
P0455=EVAP Emission Control System Leak (Large Leak)
Possible gas cap fix, cheapest try first.
Check the gas cap thoroughly, the P0455 code your getting for the large leak isusually a bad gas cap.
Also check the lines on the canister tank,right underthe passengers side of the cab, there are two lines on top that will rotand fall off or get loose enough that they will cause that problem.
You can also check on the passengers side fender well under the hood andlook at the elbows on the EVAP valve that has the hoses that run downto the canister tank, chances are one of them is loose or bad.
Best to get a factory service manual to have handy through all of this. Promanuals.net has complete factory ones for around 20 bucks. Here is a link 2001 Dodge Ram Service Manual.
Sep 28, 2009 | 2001 Dodge Ram 1500 Truck 2WD
I need to know where valve is on my truck to re
IT'S EITHER ON THE ACCUMULATOR OR THE LINE (this line is the larger of the two AC kines off the compressor) THAT GOES TO IT.THE ACCUMULATOR LOOK LIKE A 4INCH X 8 INCH CAN,WITH A PRESSURE SWITCH OFF CENTER ON THE TOP.THE LINE GOES FROM THE COMPRESSOR TO THIS CAN,THAT IS CALLED THE SUCTION LINE (LOW PRESSURE)
Aug 10, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
