Question about Whirlpool Dryers
The belt fell off of the drum, i have the front off but i dont know where the disconnected pulley goes.
  • 221 Answers
Unplug dryer or disconnect power.
Locate mounting slots in front of motor. (In some cabinets, there are two sets of slots for mounting the idler assembly. In this case, mount the idler assembly in the slots that line up under the grooves in the motor pulley.)
Install idler assembly into cabinet base by hooking mounting tab (A) into 1⁄4" wide mounting slots and setting mounting tabs (B) into the 3⁄16" wide mounting slot.
Make sure belt is around drum, with grooves down.
Route belt through the idler and around the motor pulley.
Posted on Sep 12, 2009
Maytag Dryer- Drum not rotating (belt and motor both work)
I surely do hope this fixes it all.
The pulley that fell apart is supposed to. Well, not quite. It is not fastened inside the machine, and comes off easily. It is the belt tensioner. It fits into 2 slots on the bottom steel panel of the machine (The base)
You will be finding it is a pain in the neck to put back on, but you can do so. The belt goes with the grooves toward the drum, not away from it. The belt goes in a S shape around the motor pulley and the tensioner pulley. One you put the tensioner back in it's place nin the two slots, you will push (or pull) on it against the spring arm to "bend" it so as to get the belt back on.
Be blessed.
Jun 19, 2013 | Maytag Dryers
How do I get the top open on maytag neptune dryer? The baffle fell off.
Hi gmaninsuranc...
I will give you a little more than you asked for, but it wise to do some maintenance while you have the dryer apart.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Note: This method workds for most front loading machines.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary.
Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please take time to rate me
Jul 09, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I replaced the belt and need to know how the tensioner goes back on
From the front with the belt around the drum in the correct position, and the drum in place. Reach in under the drum and put the belt around the pulley on the drive motor. Then find the idler pulley. It should be pulled to the base of the drier to the left of the drive motor pulley. Pull the idler pulley up and to the right and place it on the outside of the of the belt coming down from the drum to the drive pulley. It should pull back to the left and tension the belt.
May 30, 2011 | Dryers
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
I have a Kenmore 400 model 110.67422600, the belt fell off from around the drum. I do not see in the manual any directions to do so. Is there any manuals online that I can view or what steps do I need to...
First, make sure the belt is not damaged. Secondly, belt goes around the drum first. then around the motor pulley. And last, around the tensioner from the farthest side of the pulley. Good luck!
Jun 29, 2009 | Dryers
Putting a belt on a whirlpool belt
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side and loop it around the motor pulley.
Let me know if you need more assistance.
Mar 15, 2009 | Whirlpool LER4634PQ Electric Dryer
Pulley fell off while reassembling kenmore dryer 80 series
the pulley goes right beside the motor pulley,the belt goes under the big pulley and onto the motor pulley-mike
Mar 03, 2009 | Kenmore 659 Electric Dryer
New belt runs too close to drum on pully
adj belt in motor pulley groves 1 grove at at time spin with hand to center on drum pulley
Dec 07, 2008 | Frigidaire ATF6000ES Front Load Washer
How do you replace the drum belt on a Maytag DE610 dryer ?
OK, this one's a few years old. First, of course, disconnect power to the machine. Second, remove the two phillips head screws, one at L and one at R near the bottom corners of the front panel. Third, pull the bottom of the front panel toward you and unhook it from the dryer's top. Swing it to the side. You do not have to disconnect the wires to the door switch. Fourth, remove the four 5/16 hex head screws holding the drum supports and set it aside. Fifth, put belt around the drum. The smooth side of the belt touches the drum. Sixth, belt goes to the motor drive pulley and then around the belt tensioning idler pulley. Seventh, put the drum support part back on and turn the drum by hand to make sure the belt tracks OK and has no twists in it. Eighth, finish reassembly and test. Note: genuine Maytag belts usually have installation instructions on the back of the package, with a couple diagrams.
Sep 16, 2008 | Maytag Dryers
My dryer needs a new belt. I opened the front panel and removed the broken belt but I am not sure how to put on the new one. I know it goes around the drum but does it go in the middle or near the back...
Cheryl the belt goes in line with the pulleys. 1st Put the belt around the drum. 2nd put the belt around the pulley on the motor. 3rd pull down on the idler pulley and set it so that is pushes on the back side of the belt. Remember the ribs on the belt go against the drum. When done the pulley will take up the tension on the belt. Hope this helps.
Aug 09, 2008 | Dryers
Dryers Logo
59 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
