Question about Tomtom ONE 125 GPS Receiver
Req voice selection everytime and reboots when selected
It used to work fine - for about a year.
My tomtom is in an infinite loop. When I start it, it now requires you to select a language. Unfortunately when I do it starts to freeze up and then restarts itself sending me right back where I started. The long/short of it is that it no longer works.
I am currently running Windows "Error Checking" on it with both "Automatically fix file system errors" and "Scan and attempt recovery of bad sectors" checked. I'll post if it works.
  • 3,153 Answers
DONT error check with windows this can cause errors itself !
HARD RESET
Tends to fix quite a few problems and is specific to TOMTOM's that have the tiny reset hole on the bottom of the GPS
Commonly known as a "hard reset"
You need a paper-clip or something similar ( Avoid needles )
Paper clip in the tiny hole by the card slot.
Push it in firmly whilst the unit is powered up (not too hard) for about 3 seconds then release
You may have to power down and then up again and even hold down the power button a little longer the first time you do this
You may also have to do this without an SD card in.
If you have a card in then the windows error checking may give you some issues.
You may have to re-format the card (FAT-32)
And copy your tomtom files back to it from the tomtom itself..
Posted on Sep 12, 2009
Unit is one year old. Worked fine this morning, got back into car and GPS asking set-up questions but a the time prompt it flashes off and starts the set up over againi with language prompt. Keeps...
try this originally posted by gt3rs i just did it and it worked for me Here is a solution that worked in my case (constant reboots after voice select)
  1. Plug your tomtom into your PC.
  2. Run TomTom Home
  3. Select the option to run your TomTom through your PC (TT Home)
  4. You should be greated with the select language screen
  5. Then simply select language etc.
  6. When you get to the voice selection: select a voice (here TTHome should freeze) <- also strangely enough notice the cancel button doesn't on the screen (as it does when doing this on the device)
  7. Don't panic TT Home should start working again in a few seconds
  8. Disconnect your TomTom and that should have solved the problem, the normal map screen should show up upon starting up your TomTom
This solved the issue for me, hope it does for you good luck!
May 10, 2011 | Tomtom One XL GPS Receiver
My Tom Tom One unit works OK but I cannot get any sound. There is a red cross on the Turn Off Sound but I cannot change it. When I try it flags 'You did not select a usable voice.'
You have not set a (male or female) voice to be used by your Tomtom One device:
use 'Change preferences' -> use Right arrow to get second creen for your preference 2 of 5 -> 'Change voie' -> scroll to 'select a voice' -> Click 'Test' to hear selected voice sample dialog -> Finally, click 'Select' when you are happy with the selected voice.
If you need additional voices, use TomTom Home to download them.
Hope it helps: let me know how you go!
Jan 07, 2010 | GPS
Tom Tom stuck in a loop
i had the problem that when selecting the voice, the device would freeze up then restart sending me to the beginning of the preferences. what i did to fix this is connect the device to my laptop and start tomtom home. on the third page select operate my device. this let me finish selecting the preference options through the computer. after that my gps came up.
May 05, 2009 | Tomtom ONE 3rd Edition GPS
My tom tom keeps looping on the start up menu
I to had this same problem. I just about pulled my hair out. The way I fixed mine was to use Tom Tom Home to operate the Tom Tom. It was able to get past the loop and finish the initial set up. I then unhooked it from the computer and it was working by itself.
Mar 10, 2009 | Tomtom One Europe v2 GPS Receiver
My gps does not read streets names
To get your TomTom to speak street names, you will need to change the voice from a recorded voice to a computer voice. This can be done by:
  • Connect your TomTom to your computer
  • When the TomTom asks do you want to connect to the computer, choose Yes
  • Open the TomTom Home application
  • Click on the 'Add Traffic, Voices, Safety Cameras, etc.' button
  • Click on the 'Voices' button
  • Click on the 'Computer Voices' button
You can now select a voice to install on the device.
Once you have installed a voice, change it by
  • Disconnect the TomTom from your computer
  • Turn on the TomTom
  • Touch the screen to bring up the menu
  • Touch 'Change Preferences'
  • Touch 'Voice Preferences'
  • Touch 'Change Voice'
  • Use the Left / Right arrows to navigate to the voice you just installed (Look for the word 'computer' in the upper right corner by the male/female option)
  • Touch the 'Select' button
Jan 02, 2009 | Tomtom One XL GPS Receiver
MY TOMTOM ONE DOES NOT GIVE ME SPOKEN STREET NAMES AS THIS MODEL SHOULD,CAN U GUIDE ME THE SETTINGS
These steps are for my TomTom One (2008) model.
1. Once you have turned on your TomTom tap the screen.
2. Tap 'Change preferences'
3. Tap the arrow to get to page 2 of Preferences
4. Tap 'Change voice'
5. Tap arrows until you get a computer voice - I chose Samantha.
6. Tap the 'Select' button to the right of the voice picture.
7. This screen is labelled 'Speech preferences' and the first one is 'Read aloud street names'
8. Tap the box to the right to select this preference.
Good luck.
Sep 12, 2008 | Tomtom GPS
Set up voice John Cleese
You need to put the File / files associated with the voice onto your SD card in the Voices folder.
Use an SD card reader and your PC to look on the TomTom SD card. Find the folder called "VOICES". Copy the John Cleese voice files into the "VOICES" folder.
Once this is done put the SD card back in your TomTom. Switch on. When the TomTom starts up , tap the screen and select "Preferences" , then move through Preferences until you find "Lips" icon and under that it will say " Change Voice" . Tap the Lips Icon , then move right or left until you find the required / John Cleese Voice and select that. Your Tom Tom should now give directions with the John Cleese voice.
Please note: Some voices that you can download free of the internet can contain viruses or if you are unlucky they can contain faulty data which can effect the workings of your TomTom.
As a precaution , before you copy or alter or add anything to your TomTom SD card you should make a Backup of your SD card onto a PC. The if anything gets upset on your SD card you can always format it and restore the origonal data.
Good Luck.
Sep 08, 2008 | Tomtom ONE GPS Receiver
Tomtom keeps rebooting by itself soon after being switched on
  2. Run TomTom Home
Aug 22, 2008 | Tomtom ONE GPS Receiver
Tomtom ONE 125 GPS Receiver Logo
199 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
