Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Change oil light stays on after I change oil.
  • 40 Answers
Try disconnecting the battery, wait 5-10 minutes, then hook it back up. This hould reset the warning lght
Posted on Sep 12, 2009
2005 Suzuki boulevard c-90 I changed oil and filter but the oil light stays on so I changed the oil and filter again and the oil light is still on .
Hi, Gene you may have air in the system try bleeding it out like you would for brakes by loosening the oil pressure switch or oil filter with the engine running and watch for bubbles when they stop re-tighten and your good to go, for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Red Oil Light Stays On
Oil light coming on
Suzuki C90 Oil Change and Final Gear Oil Boulevard
Suzuki VL1500 Service Manual
OEM parts for Suzuki
Suzuki VZ1500 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 21, 2016 | 2005 Suzuki Boulevard C90
Why does the Change Oil light stay on 15 seconds after starting car?
Try re-setting the oil change light and see if it quits. Should re-set itself. Not oil sending unit, that tells computer and light when there is a problem like no oil pressure.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2496c4f07ad24453
Sep 02, 2014 | 2003 Chevrolet TrailBlazer
Why does the Change Oil light stay on for 15 extra seconds?
TAKE THE TRUCK BACK TO PEPBOY AND TELL THEM TO RESET THE SERVICE INDICATOR
Why does the oil light stay on?
weak oil pump blocked oil filter or oil ways try using flushing oil and then change the filter
May 10, 2014 | 2001 Volvo S40
Oil can light stays on
Run a Scan on it first but also check the Oil Pressure Sending Unit and the actual Oil Pressure with a Mechanical Gauge. You may have a bad oil pump.
Feb 13, 2014 | 2008 Ford F 250 Super Duty 4WD
Oil pressure light stays on even though the oil level is fine
That could be from not having any oil pressure "oil pump failure, clogged filter, etc" or from a faulty oil pressure sending unit. More tests would need to be performed but is it really an oil pressure light or is it the change oil light. More info would be needed
Jan 30, 2013 | 2006 Chevrolet Malibu
What's your problem?il oil light stays on
there is a oil pressure switch on the oil filter hosing did you knock the wire off when changing the filter?
May 29, 2012 | Mtd Cub Cadet 48 In 22 HP Kawasaki Engine...
My engine oil light stays on all the time even
have you tried changing the oil sending unit they can get bad also make sure wire to sending unit did not get pulled off
Oct 22, 2009 | 2000 Chevrolet Tahoe
Oil light stays on
You need to put the key on and push the gas pedal to the floor three times within five second to reset the oil life light.Some g.m.'s have a reset buttom in the fuse panel that needs to be pushed first and some don't.Check the owners manual under change oil for your specific year car.
Oct 21, 2009 | 2003 Chevrolet Impala
Check oil light stays on even after a full oil change
The oil pan has a sensor in it that need to be replaced. It screws in and you may lose some oil.
May 09, 2009 | 2001 Chevrolet Malibu
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
119 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
