Question about LG Washing Machines
I have a lg tromm. it lights up, but when you choose your cycle and hit the start button nothing happens
  • 6 more comments
  • jones285 Sep 12, 2009
    The serial # is 408kw the door does not lock. The start button continues to flash and nothing happens when you push it.Its done this a few times before but it has always started before.
    the model # is wm2277hw
    Lg tromm front loader washer lights up but when you push the start button nothing happens. the start button continues to flash.model #wm2277hw serial #408kw
    Door is not locking. Checked ohms .7to .8 across the board. Normally when i choose a cycle and hit start button door locks and then water starts. Now when i choose a cycle nothing happens at all, light just continues to flash.Also tried QCtest mode nothing happens.
    lg tromm front loader. model # wm2277hw serial # 408kw.Machine lights up when you turn it on but when you push the start button nothine happens.It allows me to choose cycles but thats it. Tried using the QC checks but it wont do anything.Did ohms check on door switch Read .8 across the board.
    wm2277hw
    lg tromm model# wm2277hw serial # 408kw machine lights up when you hit the power button but thats all . I can choose cycles but start button does nothing but blink . there are no codes. tried qc check but that did not work either.
    wm2277hw
  • 691 Answers
Good sign if the machine lite up and everything else is working. check the door latch switch, if the switch is faulty, the machine wont turn on its a safety device.
Posted on Sep 12, 2009
    Top Expert:
  • LG Master
  • 76,673 Answers
What is the model number of the machine please.
  • yadayada
    yadayada Sep 12, 2009
    what is the model number of the machine please.
  • LG Master
  • 19,396 Answers
Re:"the door does not lock. The start button continues to flash and nothinghappens when you push it.Its done this a few times before but it hasalways started before."
If there is no error code on display, that means that either door lock or timer control board is causing your problem.
Door lock is tested reading Ohm with a multimeter to check if the latch switch is opening and closing the circuit.
If the lock switch is OK, then the technician will check if there is power to door latch, then test control timer board and eventually replace control board.
If the door is locking, then following parts must also be tested:
Lid switch, membrane switch, drain system, inlet valve. MCU and motor. If door lock is OK also ensure that the belt has not slipped out.
If door lock is stuck, then it is door lock or control board.
Here below all parts and diagrams for your appliance.
Lg WM2277HW - Model Information at Appliance Factory Parts
Please do not forget to leave feedback
Thanks
  • 1,543 Answers
You are a little short on information here to fully trouble shoot your issue. If the door locks when you push the start, but nothing else, that would indicate a water fill issue. If pushing the start button has absolutely no response, then it sounds like the control board containing the push to start is the most likely culprit. It is possible that an electrical plug on one of the boards is not tight and therefore not making contact. I can not give more complete info without more info from you, including the full model and at least the first three numbers of the serial number. (found on the frame just inside the door)
LG Tromm Steam Washer Cycle is complete and the stuff is so wet that they have to wrung by hand to even put they on a clothes line. Can washer be put on spin only? How?
call a technician as it indicates that the cycle from rinse, spin is not progressing to spin only
rinse,spin is a low speed spin to facilitate the rinse and to balance out the clothes ready for the fast speed spin cycle
Feb 25, 2017 | LG Washing Machines
My LG Tromm dryer makes 3 clicking sounds when I push the start button. Everything lights up as if it is going to work, but when "start" is pushed, I just hear the 3 clicks and then nothing happens
If the drum doesn't turn, check the centrifugal switch on the motor shaft. Check if the belt hasn't broken or if it's off the motor shaft.
Jul 16, 2014 | Dryers
How may belts on lg tromm dryer
The start button is a momentary start button. It energizes a relay type switch to keep power on. Try holding the start button in for awhile and do not let go. If the machine keeps running, then for sure, the relay type switch is defective and needs to be replaced with a new one.
May 24, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm washer wont spin through the spin cycle and reads error ue. I have tried to balance the load several times and still get the same error.
This error generally happens when people try to run a bulky load, like a coat, rug, pillow, etc., using a high speed spin. For these loads, choose the low speed spin. After the cycle completes, if you think the clothes are too wet, power up the machine again but instead of choosing a cycle, just push the spin speed button until it shows the next higher spin speed (usually about 14 minutes will show on the display) and push start. The machine will usually be able to get to a faster speed now, as the clothes have some of the water spun out of them from the earlier low speed spin, allowing the machine to reach a higher spin speed without the Unbalance Error code showing up. Of course, you want to make sure the machine is on a solid floor with all the legs adjusted properly also.
Jan 02, 2011 | LG WM-1832C Front Load Washer
Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Jul 20, 2009 | Washing Machines
I need the user manual for my lg tromm wm2277hw because I don't know how to get it to spin without going through the whole wash cycle
for a drain and spin : turn unit on hit spin Button 1 time then start/pause button
this a drain and spin only..
Jun 15, 2009 | LG WM-2277HW Front Load Washer
LG WM2277HW trouble
take off the front kick plate on the bottom and there is a pea trap thats conected to the pump twist it off and see if it is cloged thats what usaully makes it not spin
Aug 11, 2008 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
71 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
