My Gateway M6121 laptop will not boot to harddrive or CD drive. The bios is not finding either EIDE device, but if I remove the harddrive the bios finds the CD drive? I have tried known good harddrives so I am guessing its something on the motherboard. Any ideas where to start to troubleshoot the problem?
  • n0nne Sep 12, 2009
    I should have added that to my orignal post. I have reset bios setting to factory default. Ok so now I have pulled the motherboard and in the process found a small e-clip floating around on top of the motherboard. I am guessing that it has shorted something out, though no viewable damage can be seen.
  • 74 Answers
First its better try to set up your bios to optimized value so it will run in factory default.
Posted on Sep 12, 2009
Will xw4300 accept compaq S6200cl hard drive
HP XW4300 Workstation Desktop PC specs,
http://h18000.www1.hp.com/products/quickspecs/12260_na/12260_na.HTML
Scroll down to you come to the bold heading -
Standard Features - Specs
Go down the chart on the left side until you come to -
Interfaces Supported
1 SATA 3Gb/s interface (4 Serial-ATA connectors), 1 EIDE interface for optical drives
One EIDE interface. That is the Blue 40-pin connector, on the right side of the Ram Memory slots. (39-pin actually)
(Right next to the Black Floppy Drive 34-pin connector, and above the 4 SATA connectors)
Compaq Presario S6200cl Desktop PC >Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=390423
Product Information > Product Specifications > Product Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00056951&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=390423
Scroll down to the bold heading -
Hard drive
120GB Ultra DMA
It is an EIDE harddrive.
http://en.wikipedia.org/wiki/Parallel_ATA
HP XW4300 Workstation motherboard example,
http://www.ebay.com/itm/HP-XW4200-XW620-DDR2-MOTHERBOARD-358701-001-SOCKET-775-/110904128317?pt=Motherboards&hash=item19d266b33d
The answer is Yes.
Connect just the EIDE harddrive from the Compaq.
Make sure the correct jumper pins on the back of the harddrive, have a jumper cap on them to set them to Single;
OR,
The IDE harddrive model you have may Not use a jumper cap on any jumper pins, for some models of harddrives, to set the harddrive as Single.
Look up the harddrive jumper settings on the internet.
Start with the model number on the label of the harddrive.
Example; WD2500JB
Western Digital 250GB harddrive that is IDE. (EIDE)
Western Digital jumper settings for IDE (EIDE) harddrives,
http://wdc.custhelp.com/app/answers/detail/a_id/463/c/123/session/L3RpbWUvMTM1MjE4NDY3Ni9zaWQvQnoxcVF6YWw%3D
You will need a SATA optical drive now.
BIOS Setup > Boot Options > Set the first boot device to CDROM.
Install Windows disk.
Use IDE harddrive, and IDE optical drive on the same flat ribbon IDE cable?
Can be done, but usually is a HEADACHE, and MAY not work.
BIOS looks to see what drives are connected. It looks for the drive with the Operating System on it. (Windows)
Now put a disk in the optical drive. Time has to be divided between the harddrive, and the optical drive.
IF it does work; when you are using the computer, and the optical drive you will know the real meaning of Slow.
Have a SATA optical drive?
Regards,
joecoolvette
Nov 05, 2012 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
Hi Im having a problem booting, it appears on my screen PXE-E61: Media Test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating System not found. How can i fix this one without a...
it's trying to boot up from the network instead of from your harddrive. It could mean that it's unable to find your harddrive. One thing to check is the BIOS settings for the boot option - make sure the harddrive boots BEFORE it tries to boot from network.
Once you turn on your laptop it will tell you what to press to get in to the bios to change these options (could be either F1, F2, F10, DEL or maybe even something else) Once in the BIOS look for BOOT OPTIONS
May 04, 2011 | Toshiba Computers & Internet
I have a gateway laptop .it has its hard drive with an operating system already installed properly but it does not boot. both the cd drive and the HDD are recognised in the ...
Do you have an operating system installed already?
If none yet, insert a Windows XP/Vista/7 into the cd drive and install it on your laptop.
Then just follow the instructions on the screen.
Mar 07, 2011 | Computers & Internet
Cant start my laptop it reads "reboot and select proper boot device and the screen is black ?
Go in to bios by pressing del key sometimes F2 or F1 and see if your harddrive is set to 2nd highest boot priority.Set your CD/DVD drive to first. Save your settings and exit. Remove any cd's/dvd's you may have in your drive plus if you have a flash drive plugged into the usb port unplug it before starting.
If you still have this problem, your harddrive might have a problem with the booting files on it. Reinstalling or repairing windows will fix this. Put your windows disc in and boot to it.
Hopefully you wont have a problem installing or repairing windows or your harddrive could be bad. Before buying a new harddrive for it try removing it from the bay and reinstalling it, in case of a bad connection (example:harddrive wasn't fully connected.).You could go into bios and see if it shows up there.
Hope this helps ya.
Jan 10, 2011 | Computers & Internet
How do I reformat the harddrive if windows wont load?? I have a virus and everything froze, so I tried rebooting windows with a cd rom so i could wipe the hard drive, but i get a message that windows...
That sounds like you have a very nasty virus that has infected the memory.
Switch off, unplug and remove the battery.
Using just the AC adapter, place your OS disk in the drive and as the laptop gets to the BIOS option, press F2 or whichever F button lets you in to set your master boot device as DVD/CD Rom.
close the laptop down and remove the AC Adapter.
Plug the AC Adapter back in and boot the laptop, that should get you into the CD ROM disk for formatting and replacing your system. I hope you remember to download all of the required drivers.
Hope this help.
Dec 12, 2010 | Gateway LT2021u Netbook
When i turn on the laptop computer, a message appears: primary hard disk drive not found, fixed optical drive not found. No bootable devices: strike F1 to retry boot;F2 for set up utility. I tried but...
Your BIOS is looking for a drive to "boot" from and does not see your harddrive or CD-rom.
You may have a harddrive failure or bad drive controller.
One way to see is to load your operating system disc in your CD-rom and see if the computer sees the drive and boots up. If it boots, try to locate your "C" drive. If you can't locate the harddrive, it's a good bet it's damaged.
If the CD-rom doesn't boot, it is most likely a bad drive controller or cable.
Dec 30, 2009 | Computers & Internet
Gateway mx6453 wont boot up- oper system not found
Restart the computer while tapping the deleate key this should bring you to bios go to advanced and check if the harddrive is listed with it highlighted press enter to enter the sub menu make shure its not disabled if it is enable it hit escape key to exit sub menu go to Boot on main menu set hard drive as 1st boot device set cd/dvd drive as 2nd boot device press f10 to save changes and exit. Try restarting
if you get msg opperating system not found use the system restore disk
Hope This Helps good luck
Please leave feedback
Nov 26, 2009 | Gateway MX6453 Notebook
PXE-E61 Media Test Failure Check Cable on compaq presario 2100
A PXE-61 error message is most likely a faulty hard disk.
Try reseating the hard drive first and if you still get this error message again then you need to replace the hard disk.
To boot up with the CD you maybe able to press the F12 function key when you power up the laptop, this will bring up the a menu option to select an alternate boot device. If this option is not available then go into the BIOS configuration and change the bootup order and make the CD as the first boot device and the hard disk as the second device. You can can it back later.
Sep 14, 2009 | Compaq Armada E500 Notebook
Remove disk or other media
Go into your BIOS and goto set boot up devices you can use your CD-ROM too Boot up or Harddrive remove the 1.44 Stiffy Drive from the Bootup. When Starting up press F2 to go into the Bios-Boot devices and just follow the Directions on the screen.
May 30, 2009 | Acer Aspire One A150-1006 Notebook
Replaced harddrive and dvdroom wont recognize in bios
Goto bios menu. And change the setting on hard drive and cdrom. It could be it still set in the old configuration. Try to set it in auto detect. Then save the setting. Then goto bios once again to check if the settings doesn't change. Restart again and wait if something you didn't expect still happens.
Leave a comment if this solve cd rom detection.
May 12, 2009 | Gateway M-6750 Notebook
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
