Question about VIA Asus K8V-MX K8M800 Chipset 800MHz FSB DDR400 Socket 754 microATX Motherboard with On-Board Video... (MB75ASK8VMXX)
Asus k8s mx not boots but fan rotates and without
Asus k8s mx Mobo not boots but CPU fan rotates and without RAM if powered long beeps audible.
  • 79 Answers
Long beeps are saying 'no RAM'. Any beeps with RAM in place? Remove BIOS battery (silver) for 10 mins to return to factory defaults.
Posted on Sep 12, 2009
Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
ASUS K8S-MX PC powers up but no display on monitor and no error codes. Hard drives spin and sounds as if it is in boot routine
OPEN UR CPU AND OUT UR RAM FROM MOTHERBOARD AND START UR PC WITHOUT RAM IS IT BEEP OR NOT IF IT BEEP THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC IS IT OK
IF NOT THEN PICOUT BATERY CELL 2032 FROM MOTHER BOARD AND THEN START UR PC
IS IT BEEP WITHOUT RAM AND CELL IF YES THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC
IF IT IS OK THEN CHANGE UR BATTERY WITH NEW ONE
IF UR PC BEEP WITHOUT RAM BUT NO DISPLAY WITH RAM THEN CHANGE UR RAM WITH NEW ONE.
Jul 01, 2009 | ASUS K8S-MX Motherboard
Asus A8M2N-LA MOBO fans spin but no beeps or anything else
try by switching on the comp.without ram ,check weather the motherboard gives any beep
If No then take out motherboard from chassis ,and try to power on the comp. with some barrier bet chassis and mother board
Mar 15, 2009 | Computers & Internet
No display on my asus P4GE-MX mother board
Is there any beep from the motherboard? First thing that you need to check is the RAM. unplug the power cord and remove the RAM. Now, plug in the power cord and try switching the Comp and see if there is a any sound from Mobo. It should idealy warn you that there is no RAM with continous BEEP. If that happens, the Mobo is fine.... Grab a new RAM and try it out. The system should boot now. (If there was "No RAM warning beeps" when you switched on the system without RAM). There are many issues that may put down the Mobo but in most cases its the RAM that stops functioning... Try this and see if it helps. Please post your result here so that we can see if you need further assistance.
Feb 09, 2009 | ASUS P5PL2 Motherboard
Pc is not booting and no display in monitor
First, try resetting the CMOS. If it is not working, replace the RAM. Could be a damaged RAM
Sep 11, 2008 | ASUS (P4BGV-MX) Motherboard
PC wont boot, not even to bios
Maybe the mobo is shot for u and he has his PSU shot.......Check for any burnt smells from the mobo. See if the cable from the PSU is properly connected to the mobo. Try removing all drives like graphics cards, RAMS one by one and see if it works.
Aug 18, 2008 | ASUS P4S800-MX Motherboard
ASUS P4SP-MX motherboard no POST and no beep without ram
Try removing everything attached to it. The only thing should be the cpu and cpu fan. Turn it on. If it is the same, then it is your motherboard. If you do get the beeping, then start installing things one by one starting with the memory.
Jul 03, 2008 | ASUS P4SP-MX Motherboard
PC WONT START ASUS A7S8X-MX
So if i'm getting this correctly your computer will not boot even with just the basics.  Have you tried directly shorting the pins on the mobo instead of using the power button?  Unlikely problem but it would be an easy fix.  You might also want to take your power supply out and get it tested.  The geek squad at best buy will usually do that for free, or you can buy your own tester, or buy a cheap power supply.  If both the switch and power supply are good and you get nothing trying to start it up it means you probably have a bad mobo.  If your memory or cpu was bad and nothing else it would still boot up just without anything on the screen and might give you a series of beeps.  Well I hope i've helped and that you can get this fixed soon.
Oct 15, 2007 | ASUS A8S-X Motherboard
Computers & Internet Logo
200 people viewed this question
Top VIA Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
jason
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
