Trying to hook up motorola DCT224 cable box to my TV - get guide ok but not getting channels to come in
  • 15,935 Answers
If the guide appears - the problem lies with the service provider.
You will need to call them to enable your box.
Have the serial number handy - they will need it to allow your box to connect to the system.
Thanks for using FixYa!!
Posted on Sep 12, 2009
Motorola DVR Model DCX3501-M front display shows the channel selection. I want it to display the time of day and only show the channel selection when I am changing channels. The manual is of no help
It is a cable provider setup within the menu. On charter here are the steps - menu, TV guide main menu, setup, Cable box setup, front LED display.... I don't know what these other people are trying to answer for you...lol. You can also adjust the brightness display by pressing power followed by menu (starting with the tv on).
Jul 27, 2012 | Motorola Televison & Video
Cannot download TV Guide schedule-Verizon FIOS
With this problem I will suggest you to contact Verizon or motorola so they can help you better with this concern this is the number 1-877-466-8646....
Hope that helps.........
Sep 15, 2008 | Panasonic DMR-E85H DVD Recorder
I have a motorola dch70 cable box from comcast. I recently hooked it up and set it on top of my TV. I cannot get any info on channels or any info when I hit guide. If I hit the ondemand button it says...
you say that it works if you move it away from the tv set, its due to the electrical interference of the high frequency internal tv signals with that of cable box, you need to shield/reduce the interference by either moving the box away from tv set or placing the box on a grounded metallic plate on the tv set
Jul 29, 2010 | Televison & Video
I have a VIZIO LED/LCD VF551XVT hooked up to a motorola HD DVR with a HDMI cable. When I switch from standard Def to High Def channels I lose the sound. If I turn the TV off/on the sound returns but if I...
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Feb 01, 2010 | Vizio VF551XVT 55 in. HDTV
Phillips dvdplayervideorecorder connect w/zinwell converter box
First off get the TV on the right channel. It will either be ch3 or ch4. If you are using a cable box the dvd/vcr combo will have to be on ch3 or ch4 as well. OK, Make sure the input connector on the combo is hooked to the output connector of the cable box and the output connector of the combo is hooked to the input connector of the tv. Deal with one part at a time. First hook the combo to the tv and get the tv on the right channel (ch3 or ch4) so that you can see a pre-recorded dvd or video play. Then you will know what channel the tv is supposed to be on. When you find it don't bother the tv channel any more. Stop the dvd or video and hook up the cable box and turn on the cable box and set the box to a known good channel. Now put the combo on ch3 or ch4 with the combo's channel selector buttons until you see the cable box playing on the tv (remember you already set up the tv channel). Change channels on the box but don't bother the channels on the tv or combo anymore. You can put the box on whatever channel you want. The box will be your channel selector. I certainly hope that this helps. I know it can be confusing but don't give up. Just remember that the tv and combo have to always be on ch3 or ch4 (which ever one you found before). Good luck and thanks.
Nov 01, 2009 | Televison & Video
Ok my timewarner cable box works i pull up the guide and selet the channel i want but there is not sound or picture coming from the tv.
unplug the box and let it reset for at leat 4-5 min, if this does not fix your problem call time warner customer suppport, they can reset your box over the cable line if needed. Good luck.
Oct 27, 2009 | BoxWave Corporation Motorola RAZR V3...
Tv not working with cable box
Insure your TV is set to channel 4. Then go into your TV's menu and make sure it's set to CABLE and not AIR. There is no need to program your tv, as long as it's on channel 4 and set to recieve Cable it will be fine.
Mar 26, 2009 | RCA F27665 27" TV
Cant get digital channal on my DCP 501
From page 24 of the Installation Section
The clear protective film on the DCP501 display must be removed and transferred to the inside back cover of your
DCP501 Home Theater System User Guide. The Unit Address and Serial Number found on the protective film is
required for activation of your DCP501 cable TV receiver by your cable TV service provider.
On Page 28 -
Do not disconnect the cable connection between the RF In and To RF In ports. Removal of this
cable could disrupt operation of the DCP501.
IMPORTANT! The digital cable feature of your Motorola DCP501 can be activated only in
certain cable systems throughout North America. Contact your local cable TV provider to
determine whether the digital cable feature of your Motorola DCP501 can be activated. In cable
systems where the digital cable feature cannot be activated, you may connect an external cable
receiver provided by your local cable provider. For best results, connect an external cable
receiver through the audio and video inputs on the back of your DCP501.
Page 74 -
Using DCP501 Cab le TV Functions
The DCP501 has an advanced CATV set-top terminal that allows you to view cable channels.
The DCP501 must be authorized for cable TV operation by your cable TV operator before it will
tune channels.
To use your DCP501 to view cable channels:
1 Press SOURCE to display C ATV on your TV. C A TV and the last channel tuned are displayed
on the DCP501 display.
2 Press MENU to display the TV program guide on your TV.
3 Press GUIDE to display the television program guide on your TV.
4 Change channels by pressing CHANNEL/PRESET���� or making your selection with the
If you receive an electronic message from the cable operator, the message icon �� turns on.
You must use the TV program guide to retrieve an electronic message.
Additional DCP501 cable TV functions include CATV Record and CATV Channel Scan.
If you don't have the manual go to:
http://www.retrevo.com/support/Motorola-DCP501-Receivers-manual/id/393bh936/t/2/ and register to get it. It's free.
Mar 21, 2009 | Motorola DCP-501 Receiver
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
How to hook up cable and get more channels than 2-13????
Change setting in menu to cable from tv or antenna. May be in channel setup menu.
May 12, 2008 | Televison & Video
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Electro Med Services...
