Question about Cell Phones
306 1600 petrol 1995 failed mot on emissions co
306 1600 petrol 1995 failed mot on emissions co high hc high lambda fail loated to replace either cat or oxy sensor no oil showing in sump but lots of oil in air box and pipe from top of rocker cover is there a crank case breather pipe on this engine or what may be causeing the problem and what is the solution
WHAT WILL HAPPEN IF I REMOVE MY CATALYTIC CONVERTER ON MY MAZDA 6 2005 MODEL?
if the cat is a stand alone cat with no downstream lamda sensor then all that wil happen is the emissions will be high if in the uk that would fail the mot test 1 having no cat fitted if that model/year should have plus out of spec emissions if its got a downstream lambda and removed/disconnected will display a engine warning and put the engine control module into default
Mar 21, 2017 | Mazda Cars & Trucks
Help please guys Low idle 760rpm CO 0.78% above 30 fail Hc 193ppm Lambda 1.03 pass Fast idle 2780rpm CO 0.23% above 20 fail Hc 82ppm above 200 fail Any idea thanks
you have not mentioned the make and model of the vehicle
have the fault codes read and check for HO2S and O2 sensor problems
check for a failed cat converter
Sep 25, 2015 | Cars & Trucks
Emission test failed HC (PPM)
i can be, only 2 things, or both.
1: engine running way too rich.
2: dead cat.
(both happens, too)
replace the cat, might be cheaper that full engine diagnosis and repair.
in a real shop we test the cat. using up and down stream tests.
with the 5 gas analyser.
but the truth is a new CAT can hide a very filthy running motor.
Mar 12, 2013 | 1995 Geo Prizm
Golf 1.4 2003 very high emissions
Replace your oxygen sensors.
murf427
Aug 29, 2012 | 2003 Volkswagen Golf
Hi, 2000 Landrover Freelander 1.8 petrol, failed MOT on CO emissi
check both lambda sensors for breaks in wires and for open circuit on heater side of lambda sensor on the one under the car on the second cat,failed heater element will not heat gas engough for sensor to read causing false readings , also check for slow i.a.c valve on inlet manifold.
Sep 26, 2009 | 2002 Land Rover Freelander
Emissions failing with high NOx
Change the lambda/oxygen sensor in the exhaust.
May 21, 2009 | 1994 Mitsubishi Galant
High CO emissions
run the fault codes and look for problem heated oxygen sensor ( HO2S) in the exhaust manifold , or problem oxygen sensor (O2S) after the cat converter, problem EGR system or problem cat converter
Apr 05, 2017 | 1995-1997 Chevy Suburban Ignition Starter...
My chevy s10 failed emissions
Have your cat. converter checked out. I just had one of these for the same reason in my shop today.
Jul 09, 2008 | 1991 Chevrolet S-10
Cell Phones Logo
74 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
