Question about Maytag Dryers
Drum squeals at startup then quiets - once the first load goes in I can do laundry for hours without it squealing, but if it cools down it makes that noise for a minute or two.
  • karen_beres Sep 12, 2009
    this would be why the noise is worse after a couple of days of nonuse vs just a couple hours? And just how do I locate this rear bearing to grease it?
    Maytag Intellidry LDE 9806ACM - In case you have figured it out yet, I haven't done this before, so I just want to make sure I get it right - Will greasing it work or should I just get someone in here to replace it?
    President:
  • 2,923 Answers
Usually the squealing noise is from the rear bearing going bad. You need to try putting some grease on it first. If same problem occurs, replace the bearing.
Have a great day!
Posted on Sep 12, 2009
  • Melvin Ramos
    Melvin Ramos Sep 12, 2009
    Yes you are right. For dryers, the bearing is located behind or under the drum. You have to unscrew the drum, remove it and you will see the shaft going to the motor, there you will see the bearing.
    Unfortunately, I forgot to ask the brand and the exact model number of your dryer. But please check the link below so that you would have an idea how a dryer bearing looks like:
    http://dryerbearing.com/
    Have a great day!
    Regards,
    Firesnake09
  • Melvin Ramos
    Grease it first. We're still not sure if the rear bearing is bad. If it do the same thing after greasing it, then call someone to replace the bearing.
    Thank you!
How to unglaze glazed drum breaks
Rear Drums & shoes should be changed at the same time. The same goes for the front pads & rotors. Usually the drums & rotors are pre-cut but I ask at the counter if they need cutting because I have ended up with uncut squealers once or twice and found the drum needed to be re-cut due to minute warp-age. If the grinding is the same as before the brakes were changed then all th e brakes need changing not just the ones you thought needed it. Quiet pads & brakes have a beveled edge instead of an abrupt 90 degree angle. Ceramics tend not to squeak. As for un-glazing, in the old days we ran 60 grit sand paper along the wear surface until it was sufficiently scuffed to stop the squeal. It didn't work for very long & usually the squeal worked itself out with wear in a week or 2. good luck.
Aug 20, 2015 | 2005 Chevrolet Equinox
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
Feb 10, 2014 | Siemens WTXD5300US Electric Dryer
What causes my stack dryer to squeal
Dry drum bearing or roller bushing going bad. Could be the belt, but if that is squealing it will soon burn in half and the drum will stop.
Jan 06, 2014 | Frigidaire Dryer Laundry Center Service...
THE MACHINE RUNS VERY WELL QUIET UNTIL THE FINAL SPIN CYCLE THEN FROM THE BACK OF THE MACHINE THERE IS A SQUEAL THAT GETS LOADER AS THE SPEED PICKS UP
This may well be the drum drive belt in the back of the washing machine. This belt transfers drive from the motor to the drum for both wash cycles and spinning. If the belt is slipping slightly on the pulley then a squeal may well be heard on the spin cycle and will change in pitch as the speed of the drum increases. At lower speeds (wash cycles) the belt probably won't slip. I don't personally know of this model but there is usually a tension adjustment nut/bolt near the motor to tighten the belt and stop it slipping.
Dec 26, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Dryer makes a loud squealing noise
the rear bearing is gone,ge has a bearing kit that goes on the back of the drum and hooks onto the back wall,the bearing wears down and gets noisy,call your parts store,give them the model number and they'll give you the parts you need
Dec 03, 2010 | GE Spacemaker Washer and Dryer Electric...
My Maytaag dryer has a loud intermittent squeal. It will often work for 10-15 minutes with a quiet squieak or no noise, then the loud squeak starts up. I can turn the dryer off, but the squeal immidately...
I think the drum drive belt is slipping because it occurs more with a large load. Other possibilities are: A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Sep 21, 2009 | Dryers
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
Burn marks on clothing
The front felt drum seal may be bad. It is attached to the front panel, around the door.
Check and or replace the rear drum support it has worn down the ball and cup support. It will soon begin making a grinding/squealing noise.
When it wears and drops down the gap is greater at the front around the felt seal. Laundry gets caught in the gap and scorches.
Apr 20, 2009 | Dryers
Noisy dryer......when engaged...making squeaking/squealing noise.
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Dryers Logo
27 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
