Question about Dryers
My dryer makes a squeaking noise as it dries. It started doing this for a few minutes, but it now does it all the time. What's up?
    Scholar:
  • 106 Answers
There are a couple of possibilities here.
On most dryers there are dryer glides on the front of the drum, between the drum and the opening where you put the clothes in. When those wear out you have metal on metal, and hence the noise.
A second possibility is the belt tensioner. It simply holds the belt tight against the drum. It can wear out too, it's usually just a plastic wheel on a metal arm.
The third possibility I can think of is the belt. Over a period of several years, say 5+, the belt can become hard from all the heating and cooling cycles it goes through. It begins to slip on the drum and makes squeaking noises. If it's the belt, the noise will be there with a heavy load and gone with a light load of clothes.
All of these parts should be available at a good local appliance parts store. Sometimes you have to bring in the worn out part for them to match it. If it's the belt or tensioner the back of the unit will have to be opened, I recommend that you find someone that experience fixing such things, especially if it's a gas dryer, because you wouldn't want a gas leak.
Posted on Sep 12, 2009
  • 40 Answers
Sounds like a roller bearing is going bad. Oling it would only be ashort term fix. The bearing needs t be replaced
Drum squeaks on rotation. can drum be lubed?
would not lube the drum but the two small wheels that the drum rotates on sometimes their "axles" get dry and rusty and will squeak. Put some antisieze on them and see if the noise goes away.
Mar 16, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
At the start of the drying cycle the dryer would squeak for a few minutes as it heated up the squeaking would stop ;now the dryer will not turn on, only hums whn the start button is pushed..HELP!!
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 30, 2011 | Dryers
My gas dryer LG 452 makes loud noise thumping when first starting then will cease after a few minutes. Was all quite before installing recall gas valve. now very noisy when first turned on.
heatman101
Jul 27, 2011 | LG DLG0452W Gas Dryer
Maytag Gas Dryer, Performer G2300 Dryer starting making loud squeaking noises and then after about 2 dryer loads of this noise, the dryer just shut off midcycle. When I tried to restart the dryer, it...
heatman101
Nov 07, 2010 | Dryers
My dryer is squeeking and grinding, but not all the time. What could be wrong? When it first starts, it sounds like it is grinding, but continues to work. After a few minutes, it stops. Then it will start...
One of two issues is going on, or maybe both. The first cause for the grinding noise is going to be the main bearing that is bad, and needs to be replaced. The squeaking is actually coming from the belt. So I would check under the unit and make sure that you do not have any metal shavings under the unit. Then also check the belt
May 18, 2010 | GE DBL333EA Electric Dryer
Dryer makes squeeking sound when running
you need to replace the rollers an idler an belt,,,this will stop your noises...call if need help...
May 10, 2010 | Dryers
My LG DLE2514W electric dryer starting making a squeaking noise at the end of a drying cycle last night. After letting it sit for over an hour, started the dryer back up and the squeaking noise came back...
heatman101
vciku
Jun 29, 2009 | LG DLE2514 Electric Dryer
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Dryers Logo
152 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
