Need to know how many batteries? What year, make, and model? Are you using a quick charger?Need to know how many batteries? What year, make, and model? Are you using a quick charger?
You can't post conmments that contain an email address.
Make sure the batteries are fully charged. if your cart has it's own charger it may not fully charge. I would purchase a portable one and make sure they fully charge then you would know whether the cart charger is working.
<span>Preparing...<br />With the phone in the on position.<br /><br />Fully charge the battery with the phone on... (until the led turns green.)<br /><br />Once the led turns green, unplug the charger until the led goes off. <br /><br />After the led goes off, plug the charger back in. When the led turns green , power off the phone.<br /><br />now.... with the phone fully powered off...<br /><br />1. Unplug the charger. <br /><br />2. Wait until led goes off. <br /><br />3. Plug charger back in until the led turns green. When it turns green, unplug the charger again and go to step 1.<br /><br />4. repeat steps 1 and 3, 10 times. This may take anywhere from 30 seconds to 30 mins per cycle. Typically only about 1 minute. though.<br /><br /><br />DO NOT DRAIN THE BATTERY. The goal is not to empty the battery and recharge like ni-cads (those have memory, these don't). These are lithiums, so we need to do the opposite...</span>
First of all take your battery to a place that sells batteries and have it checked. Sounds like your battery is only partially charging but the charger will show fully charged as it won't charge any more. Battery could be bad.
This is the procedure for solving consider replacing
your battery problem. Start by running the command prompt with administrator privileges.
This will give the full control over the command prompt. There are those
commands that can only be executed when you are using the command prompt with
administrator privileges. Change the destination path showing on the command
prompt to be set to C:\ then type the command POWER -ENERGY( to change destination path to C:\,
type CD\ ). This command will make the computer scan the battery status and
after 60 seconds, a report will be generated and saved in C:\. Simply open the
energy report and scroll to check the battery information. Look for the design
capacity and the last full charge, note the difference in this figures.
For my laptop, these were the details Battery Information
Battery ID: Hewlett-PackardPrimary
Manufacturer: Hewlett-Packard
Chemistry: LION
Design Capacity: 88800
Last Full Charge: 36467
To remove the message consider replacing battery fully charge your laptop battery then unplug the charger to use the laptop on
battery power. Use it until the laptop
to automatically shut down. Still with the charger unplugged, power on the
laptop again. Do this until the battery is totally empty. Now plug in your
charger and charge the battery fully. Then perform the commands steps again by
running the POWER -ENERGY command. Make sure you note the differences in the
last full charge details. Continuously perform these steps until the figures in
the last full charge are more than 40% of the design capacity.
Some chargers contain a computer chip that automatically shuts off the
unit when a battery is fully charged. Other models continue to charge as
long as the unit is on. Review the instructions for your particular
charger to ascertain whether you'll have to manually turn off your
3-in-1 charger.
Hello Howard, There are two different kind of cordless drill chargers. One is a smart charger that will not overcharge your battery. It usually has a stand alone base that the battery plugs into and sometimes may have a red and/or a green light to let you know it is charged. This charger will stop charging when the battery is fully charged after an hour or less. The other one is a dumb charger that can overcharge your battery if left on the charger too long. This charger usually has a square or rectangular transformer that plugs directly into your wall receptacle. This charger may take up to eight hours to fully charge your battery and will continue to charge until you unplug it.
You need to replace your battery. When you do follow these steps to preserve battery life.
1. Fully charge battery for 24 hours
2. Make sure that you use the phone without charging it until the phone tells you the battery is low.
3. Fully charge the battery until it reaches full again.
The reason your battery is failing to hold a charge is a problem call battery memory. The less power that you use off the battery the less capacity the battery has.
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
