Question about Polaris 3/4 H.P Booster Pump
I am considering a repair to a polaris booster pump - replace bearings and seal. Is this too in depth for a DIYer ? do i need any special tools ? any tips on dissassembly/reassembly? Thanks for your advise.
    Sergeant:
    Champion:
  • 323 Answers
Just pay attention how you take it apart and make sure you put he new bearing in straight, you may need a bearing puller, and also maybe a vise to work out of
Posted on Sep 12, 2009
My polaris booster pump noise
bad motor due to bad seals leaking on motor better to replace whole pump next time
Jun 03, 2012 | Polaris Pb4 - 60 Booster Pump
My booster pump is much louder than last year. Can you oil it somehow
PLEASE DO NOT TRY TO OIL THIS, IT HAS A START SWITCH INSIDE THE MOTOR, IF IT GETS OIL ON IT IT WILL NOT ALLOW THE MOTOR TO START. AND CAN CAUSE THE MOTOR TO FAIL.
SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP REPAIR GUY, COST AROUND 125.00 TO REBUILD ONE OF THESE MOTORS. USE UTMOST CARE WHEN REMOVING WIRES FROM THE BACK OF THE MOTOR !
POOL PUMP MOTOR HAVE SEALED BEARINGS, THERE IS NO WAY TO OIL THEM, THEY NEED TO BE REPLACED. I DON'T RECOMMEND WORKING ON A BOOSTER PUMP, THERE A HARD ONE TO FIX .. SORRY .. JAY .. THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
Jun 04, 2011 | Polaris 280 In - Ground Pool Cleaner with...
My pump has a high pitched whine. Are there likely bearings out?
Yes...as the motor bearings wear they will get louder and louder. A common cause for bearing failure is a leaking seal. If you have any signs of a water leak or if the pump seal is more than a few years old you'll want to replace that when you get the bearings.
If you are handy and understand bearing replacement you can get the parts for less than $20. If not, a typical repair at an electric motor repair shop for something like this is ~$80 if all it needs is bearings to get it going again.
John
Mar 01, 2011 | Polaris Pb4 - 60 Booster Pump
Why is my polaris 280 booster pump is revving much faster than usual?
Thank you for posting your question here on Fixya.com.
The booster pump can not turn any faster than its nameplate speed. If you think it is revving up, it is probably because it is running louder and/or rougher than normal. The pump seal and/or bearings are becoming worn and will need servicing. A local electric motor repair shop should have the parts for you to buy or they could repair it for you. Often times a gasket will need to be replaced as well but all told the repair should be ~$100 or so.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jan 09, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Once the booster pump (for polaris 280) is turned on, water starts to leak badly from the front.
There is a bad seal and/or gasket in the pump allowing it to leak. It is usally the seal. Take it to a local electric motor or pump shop and the repair is probably under $50 total. You could also buy the parts to try it yourself, but the seal that pump takes (AS-1000) is a little tricky to seat properly. Besides, if your bearings are also damaged, the shop could fix that as well.
Oct 03, 2009 | Polaris 280 In - Ground Pool Cleaner with...
My pb4 booster pump is leaking from the booster pump bracket and making a ''whining'' noise when turned on????
Replacing the pumps mechanical seal should fix the leak. The whinning may be from bearing damage due to the leak. If you are unsure how to fix it, try a local electric motor repair shop. We charge about $55 - $60 for that seal and bearings installed.
Aug 26, 2009 | Polaris Pb4 - 60 Booster Pump
When running it makes a loud continuous loud noise
Your bearing are failing. Replacing them and the seal at a local electric motor repair shop will likely cost around $50.
Jun 02, 2009 | Polaris 380: Polaris Booster Pump
When running it makes a loud noise
Jun 02, 2009 | Polaris Pb460 Polaris Booster Pump...
Polaris 3/4 H.P Booster Pump Logo
65 people viewed this question
Top Polaris Garden Experts
Paul Bade
john h
Are you a Polaris Garden Expert? Answer questions, earn points and help others
