Question about HP ScanJet 5300C Flatbed Scanner
My hp scanner 5300c scanner has been problematic when installing on two different computers, causing both computers to need repair. Anybody else have a similar experience?
    Problem Solver:
  • 10 Answers
Download and install the latest driver for your scanner. The 5300c Scanjet did not ship with drivers for XP or Vista. A download is required for XP compatibility. Vista or Windows 7 should recognize the scanner without requiring additional software. If the software you are installing is not compatible it can cause issues with the computer. If you are installing from CD please look at the CD to see if it lists your version of Windows.
XP Driver Download: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=sj664en&lc=en&dlc=en&cc=us&os=228&product=58381&sw_lang=
Posted on May 16, 2010
5300c with windows 8
HP only has drivers for:
Microsoft Windows XP
Microsoft Windows 2000
Microsoft Windows NT 4.0
Microsoft Windows 95
You may be in the market for a new scanner if simply plugging it in doesn't get it working.
ScanJet 5300c cse cxi PrecisionScan software driver
Mar 04, 2015 | HP ScanJet 5300C Flatbed Scanner
Is Vista Home Premium Computer 32 Bit compatible with an HP 5300C scanner?
Your Hp scanjet 5300c scanner is not compatible with win 7 hoe premium 32-bit.hp does not have software or driver downloads available in that operating system.
Jul 27, 2011 | HP ScanJet 5300C Flatbed Scanner
Using HP 5300C scanner with Windows ME for years.
Are you still on ME? Might be time to step up to XP or vista, nevertheless, try this.. works great on my XP pro and Vista with some tweaking, but straight forward with XP Pro. Good luck! Does it show up in your hardware profiles? What does it say on details when you right click the scanner? When you installed the driver, was it before your plugged in the USB? You may have to uninstall and reinstall it again, this time use the one from HP's website with any patch if applicable.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=sj664en&lc=en&cc=us&dlc=en&product=58381&os=228&lang=en
If you have successfully used it in the past, follow the install prompts and restart.. instead of using the products software, use Windows included scanning program which is much better than the proprietary one designed by HP. As long as you have the proper driver installed your system will know how to apply it.
Jan 05, 2010 | HP ScanJet 5300C Flatbed Scanner
I've been using my 5300C scanner with Windows XP for years. Now, all of a sudden, my computer can't find it. My scanner is connected. I tried re-installing the scanner software but my computer tells me...
Most likely your scanner was put offline by a microsoft update. Mine was knocked out of business by a hardware driver update downloaded from microsoft update.
Try to roll back the scanner driver (my computer, system, hardware select scanner, properties, rollback driver to prior version) or go to your system restore function and do a restore to a earlier date when you know the scanner was working and see if that fixes it.
Worked for me. Windows XP pro
Oct 14, 2009 | HP ScanJet 5300C Flatbed Scanner
Same type of problem but Scanner Lamp is flashing 7 times
Is the scanner unlocked? Locate the lock switch on the bottom of the scanner.
Sep 17, 2009 | HP ScanJet 5300C Flatbed Scanner
Need to install HP 5300c scanner on my intel mac osx 10.5.6
Give this driver a try.
http://www.cnet.com.au/downloads/soa/HP-ScanJet-5300c/0,239030384,2113661s,00.htm
Apr 09, 2009 | Apple MacBook Pro Laptop Computer with...
Scanner 5300c
Did you install the software/driver? Did windows recognize your scanner in your hardware profile? Don't use the software from HP, It sucks. If the HP software is not working correctly, then Use the one provided my your operating system works great. Go your Control Panel, Printer and other Hardwares and click Scanners, make a shortcut to your task or start menu and Scan Away. For Faxes, etc. import in outlook or other email client, etc.
Jan 19, 2009 | HP ScanJet 5300C Flatbed Scanner
ScanJet 5300c didn't work
Most likely the destination folder for the scanning is a shared folder with limited rights. As the administrator, reset the permissions for that folder or redirect the software to a common folder with read/write/creation etc... access.
Also, make sure you are using the HP provided drivers and not those from Microsoft.
Nov 24, 2008 | HP ScanJet 5300C Flatbed Scanner
HP ScanJet 5300C Flatbed Scanner Logo
174 people viewed this question
Ben Johnson
