Question about Sanyo PLV-Z4 Multimedia Projectors
Light doesn't come on
When I turn the projector on with the remote the cover slides open but the lamp doesn't come on and then the cover slides shut.
It just happen to me and it is your light ballast that needs to be fixed. It will take 6-8 weeks to get fixed because the parts are in short supply. Cost me $350 to get a shop to fix it.
Posted on Dec 17, 2009
Projector clocked 1000 hours roughly and working fine. However 1 day I tried to turn it own and seems completely dead. no blue light. fuse r al good
Does this projector have an automatic timer that doesn't allow it to turn on after a set number of hours (@ 1000)? If so, you may need to re-set the lamp-hour clock (as if you changed the lamp even though you didn't). Some machines require you to at least slide open the lamp cover to make it think that you changed it.
Feb 13, 2016 | ViewSonic PJD6251 3D DLP Projector
Blue light flashes, lamp doesn't light
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Lim
Mar 04, 2014 | Epson ELPLP69 - V13H010L69 Projector...
I have a problem with the Sony VPL-CS3 Projector, in which it doesn't light up and the Lamp/Cover light is blinking orange while the On/Standby light is blinking red, and I don't have the remote as...
The lamp cover has a safety interlock device so the unit will not come on if the cover is missing, maybe the safety interlock is faulty or the part of the cover that engages the safety has come away. Other than that I'm not sure what the poblem would be. That is were I would start.
Good luck
Aug 10, 2011 | Sony VPL CS3 Multimedia Projector
Projector doesn't turn off when I press the off button ....I have to disconnect the power cable to shut it down
All projectors take a bit of time to shut off, when pressing the power button it first shut off the lamp, than the fan runs for some time after to cool down the lamp, have you waited long enough??? if after a minute or two, if it is still running than try pressing the power button on the unit it self, it could be a defective remote as well.
Cheers!
Jun 29, 2011 | Epson EMP-6100 Projector
Got projector out after several years of non use. Lamp would not light. We purchased a new bulb and installed it. Still doesn't work. Fan runs and all, but bulb will not light.
Check the internal power and lamp fuse. Sometimes, when a projector is stored, an area of corrosion develops around the lamp pins and lamp holder. If you carefully clean both the holder and the pins on the original lamp you may find it works OK!
May 21, 2011 | Kodak Ektagraphic III-E-Plus 35mm 140...
NEC VT595 Projector - Status light blinks red constantly
We had this same problem. In our case it turned out that a little bit of plastic broke off of a tab on the inside of the plastic lamp cover. Without that piece it was not pressing against the sensor that tells the projector that the lamp cover is closed. Without that, it doesn't start. We got it working again by drilling a little hole and sticking a screw through that spot to replace the missing plastic, but I'd rather replace the cover if I could. Really dumb that a little piece of plastic can mess up thousands of dollars worth of equipment (Smartboard 2000i).
May 26, 2010 | NEC VT595 LCD Projector
Picked up a nec MT1030+ on a gov auction with no remote. Lamp hours have exceeded the 2100 and projector is shut down. With out remote how do I get it back on? I guess I should be specific here. I have...
First make sure that you have install the bulb correctly. There are number of issues that can cause this problem.
1.Check for dirty air filter and clean if need. Make sure the air filter cover is on all the way. Make sure the cover to the lamp is on all the way, and that the screws are tight.
2. First turn off and unplug the projector. Then remove and reinstall the lamp, with cover firmly fixed. Make sure are cover are properly fastened. You should get the projector to turn on by pushing the power button on the unit. Wait for an hour if you keep having this problem, then plug the unit back in.
3. Then reset the lamp timer. Sorry I don't how to reset the timer. I home manufactured an LED lamp for mine, so I don't have to worry about replacing lamps anymore.
You might want to ask someone here on the fixya forums how to do a hard reset of the timer and unit.
You might find projector central.com helpful, where the owers manual for the MT 1030 is available in PDF version.
http://www.projectorcentral.com/NEC-MultiSync_MT1030+.htm
May 13, 2010 | NEC MultiSync MT1030 Multimedia Projector
I'm getting a flashing light for lamp cover and suddenly can't get my projector to show the show? tony
the swith that the lamp cover engages is not functioning. either the tab on the lamp door is broken off, the actuator on the switch is off, or the switch itself is broken. the lamp won't light if it thinks the door is open.
Nov 04, 2009 | Sony VPL-CX85 3000 Slide Projector
NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
May 28, 2009 | NEC VT595 LCD Projector
Lamp/cover light blinking
Myn is a Sony 3LCD and it has just let me and game funs down ;Imagine Chelsea Vs Man U and this gadget projector won't turn on,th hall is full and my oh, the lamp cover buttorn fflashng and no light,, a zbiig let ddown
Oct 18, 2007 | Sony VPL CS1 Multimedia Projector
Sanyo PLV-Z4 Multimedia Projectors Logo
239 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Electro Med Services...
k24674
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
