Question about Epson Stylus R265 InkJet Photo Printer
Epson R265 the disc print tray keeps jamming
When trying to print to disc the tray keeps coming up as jammed, reset it and re-enter and it then gets stuck again
  • bingfa_np Sep 20, 2009
    It appears to be the rollers where the tray runs under when you select to print they seem to be sticking. I can make it work but it is not perfect.
  • 95 Answers
Did you align the track? check the tray for any cracks, when you try to print cd's make sure that the printer and cd are balanced in a horizontal or even manner
Posted on Sep 14, 2009
Testimonial: "Thanks for this, I have checked and everything that you ahve suggested does not appear to be what is wrong."
Paper jam
Epson stylus paper feeder keeps jamming
Feb 16, 2014 | Epson Stylus Sx535wd
Jammed paper
You might need to update your drivers. If this doesn't help, there might be some loose gear inside the feeder . Try checking if there are also objects stuck.
Apr 17, 2012 | Epson Stylus R265 InkJet Photo Printer
Had paper jam, took several attempts to clear. I now cannot get my printer to power up?
Issue On Paper Tray... also reset you spool Tray Memory System ..Unplug Printer from PC tun off Printer ..Open Back Cover then clean Paper Jam Then Re plug printer then turn it On ...Then Try to Print Something
Oct 07, 2010 | Epson Stylus CX9400 Photo Printer
Epson Photo PX710W Unable to print on photo glossy paper. Always a paper jam message. Will print fine on ordinary paper. (Will print 6x4 size on upper tray). Help!! Geraint.
Im having the same problem, will print on normal paper but when I try to print onto Glossy paper it comes up with paper jam,or paper not loaded properly is anyone else hjaving this problem? Please help!!
Caroline.
Aug 25, 2010 | Epson Office Equipment & Supplies
Epson R265 paper feed problem
Paper feeder problem. You must open case and paper feeder.Check for all screw. spring, rubber and lubrication. If you never done, find diagram at printersiam.com. is printer paper jam berfore? and clearing jam by pulling paper form back?
Jun 28, 2009 | Epson Stylus R265 InkJet Photo Printer
When printing cd's I get: paper jam and red light and reset tray
re-download the drivers for the printing program that you are using for the job, that should fix this for you. good luck!
Mar 06, 2009 | Epson Stylus Photo R220 InkJet Printer
Re: DVD labels won't print on my Epson R265
Hello guys.
About the problems printing CD/DVD with your Epson R265 ....................
There is nothing to do. The prg coming with the printer (PrintCD) is wrong at all and we cannot understand why the Epson Corp. has simply deleted the prg by its download site.
After tryng for a lot of solutions ........ INCREDIBLE but TRUE ..... the program Print CD coming with the previous Epson R200 is ok at 100% !
So, in conclusion, all prgs inserted onto the Epson R265 CD are OK eccept the Print CD. Don't install it from the R265 disk ! It will crash !
If already installed, delete it and install the prg Epson R200 print CD.
It will work fine and without troubles.
Repeat ... it's incredible, but true.
The prg can be downloaded searching for Epson R200 software.
If you will have troubles, let me know.
Aug 23, 2008 | Epson Stylus R265 InkJet Photo Printer
How to fix paper jam Epson CX3650?
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
CREDITS: nanicool
IF YOU DONT GET FIXED WITH THIS THEN PLEASE REPLY BACK.
I SHALL BE GLAD TO HELP YOU WITH YOUR PROBLEMS.
THANK YOU
REGARDS
SWEET RASCAL
Jun 28, 2008 | Epson AcuLaser C3000 Printer
Epson Stylus R265 InkJet Photo Printer Logo
181 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
