Question about Lexmark X1240 All-In-One InkJet Printer
Problem with Printer Lexmark x1200
Every time I try to print with my Lexmark x1200 series, the paper is not printing straight, or saying the printer needs to be aligment
Bowmans IT
  • 85 Answers
SOURCE: lexmark x6170 alignment problems
Is the ink generic brand or lexmark brand?
Posted on Nov 13, 2007
SOURCE: Lexmark X3350 Printer
i think i found a solution for this.
its happen when you insert the papers to deep in the paper
jam jusy try to pull out the papers.
if its print its great , if not it should say load paper so in that
moment push the papers a little deeper.
Posted on Dec 22, 2007
  • 137 Answers
SOURCE: I need to setup the
Drivers for the X1200 series are available from Lexmark's website here.
If you are using the X1200 series under Vista the following may help.
Drivers for the Lexmark X73 are available from Lexmark's site here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Posted on Jul 11, 2008
SOURCE: Lexmark 2500 Series printer does not work properly.
my printer does not print, but tells me i have prints pending
Posted on Sep 17, 2008
yooperbud
  • 8637 Answers
SOURCE: lexmark X2470 printer wont print/connect time executable stopped
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
My Lexmark X1270 printer at one time worked, everything was good, then when I put a new color to black will not print any other color or a black color, print only a little pale, almost do not see anything...
Lexmark products work best with genuine supplies. Lexmark does not recommend the use of refilled, remanufactured, or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
You can try to clean your cartridge nozzles using the Lexmark software on your computer. From your computer, go to Start menu > Programs > Lexmark X1200 Series folder > select Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them.
If that does not help, maybe it would be best to replace your supplies with genuine cartridges.
I hope this helps.
Dec 02, 2011 | Lexmark X1270 All-In-One InkJet Printer
Do my pages print out blank
It could be that your cartridge nozzles need some cleaning. Long period of non-usage can lead to drying of ink and clogging in the cartridge nozzles. To clean the cartridge nozzles using the Lexmark software on your computer, go to Start menu > Programs > Lexmark X1200 Series folder > select Lexmark Solution Center. From the maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Then try to print your document again to verify that the cartridges are functioning now.
Nov 24, 2011 | Lexmark X1270 All-In-One InkJet Printer
My printed pages come out blank
Try to reseat your cartridges into the printer. Open the printer cover and remove the cartridges. Re-brick your printer by pulling out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. When the printer turns on, reinsert both cartridges. Try to print again to verify that the problem is fixed.
Long period of non-usage can result to drying of ink and clogging in the print nozzles. Try to clean the cartridge nozzles using the Lexmark software on your computer. Go to Start menu > Programs > Lexmark X1200 Series folder > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print your document again to verify that the problem is fixed.
If this does not help, try to insert different known working cartridges or better yet brand new genuine Lexmark cartridges.
Nov 19, 2011 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
I have a lexmark 2500 series all in one, the problem i'm having is that when i try to print, the paper does not feed in straight and then it stops feeding so i cannot print. i checked if anything has...
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Jan 14, 2010 | Lexmark X2500 All-In-One Printer
Lexmark 5400 series printer won't grab paper for printing
Whenever the printer doesn't pulls the paper please pull the pack of papers, browse through the papers with your finger and put them back gently.If it doesn't work it means the wheels that pull the paper are worn and you need to replace them.
For the second problem, this is not a printer problem but a software problem, please specify which software do you use so we can help you, as each software has individual options to print multiple pages. It will also be more logical to post the problem in the specific software area.
Good luck,
GetAFix99
Nov 17, 2009 | Office Equipment & Supplies
How to install printer ?
Just go to Control Panel...........
Printers Folder...........
There u will see a Chk mark on Lexmark Fax X1240........
And u will see another icon which says Lexmark X1200 Series just right click on Lexmark X1200 Series not the Fax and Click on Set As Default Printer...............
After u do this U can go ahead Print............
Good Luck
Feb 16, 2009 | Lexmark X1240 All-In-One InkJet Printer
Sep 13, 2008 | Lexmark X2500 All-In-One Printer
I need to setup the Lexmark X1200 series printer on my laptop but do not have the installation disk.
Regards,
Jul 10, 2008 | Office Equipment & Supplies
Lexmark P4350
Solution:
I have a Lexmark and it says that there is "No Loaded Paper" some times and when you click ok it keeps saying it. If the power light is flashing on the printer - try this suggestion.
Suggestion:
  1. Press the power button (Which will turn off printer.)
  2. Wait till flashing stops and printer is completely off.
  3. Press the same button which will turn on the printer.
  4. The Printer should automatically go back to printing.
  5. If it does not - Manually try printing by your self.
Dec 04, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
