Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
F06 light comes on and the machine fails to spin and drain the water.
  • 15,935 Answers
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
I have F 06 error code on my washer
Hi there
an F06 problem usually relates to a long drain problem the solution could mean one of the following but best to star with the least expensive first.
1.ensure that you have emptied the clog filter ( this filter usUSA.y at the bottom left of the machine behind a small door,
place a cloth on ground, unscrew the plug, some water comes out, and hopefully something that has prevented it draining correctly.
2. Ensure their is no kinks in the drainage hose ( usually a 1inch flexy hose at the back of the machine that will run into a hard plastic drainage waste pipe)
3. The pump may be a goner
4. If the heater has failed the washing machine will not drain your clothes correctly, this is an often overlooked cause when it comes to draining problems
hopefully your problem will be number one or two (DIY jobs)
good luck either way.
Apr 15, 2014 | Kenmore Elite 45986 Front Load Washer
My hotpoint keeps coming up with F06 at the end cycle with all the lights flashing as well. Many thanks
My list of Indesit (Hotpoint, Ariston) errors does not include an 'F06'!
If you have not done so already try checking that thre is no drainage blockage/stopage.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 12, 2011 | Hotpoint Aquarius WD640 Front Load...
I have a Whirlpool duet machine with an intermittent F06 code coming up at the moment. The history... About a month ago I had to deal with an F02 code relating to a very clogged filter. Cleaned that up...
wow i like a customer who has done their homework :) based on all you have checked,if i were in the home, as the technician would recommend to you to have the drive motor replaced since the biult in tachometer isn't telling the mcu what rpm's it has spun at
Gene
Aug 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code 06
In the manual for a Kenmore washer the instruction for an F06 code (electrical problem) is :
Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN/SPIN if there is excessive water in the washer. Re-select cycle and press START.
After that, you might try unplugging then plugging it in again.
Jun 06, 2010 | Kenmore 23822 Top Load Washer
Often fails to execute spin cycle with error F06
THE F6 MEANS THE CONTROL IS NOT GETTING A READING FROM THE TACHOMETER ON THE MOTOR. CHECK THE CONNECTIONS FROM THE MOTOR TO THE MOTOR CONTROLLER,(THE CONTROL BOARD MOUNTED TO THE BASE).
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine overflowed and would not drain. When it is on water keeps coming in even though the machine is full iof water but there is no movement of the agitator and I could not get it to...
H i there.....sounds like you've got either a failed water inlet valve....or a disconnected /ruptured capillary hose from the pressure switch to the tub....or a failed pressure switch........turn water to appliance off.....turn program selector to drain or drain /spin..is drain pump running...if not it may be blocked or burned out....or with machine empty of water.....turn program to spin....if no spin...check motor....
regards Sir Galahad
Aug 21, 2009 | Washing Machines
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F06 error
F06 Error
The control is unable to properly detect motor speed and the machine
will shut down. If a failure occurs during high-speed spin, the door will
be unlocked after three minutes.
1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
Aug 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
