Question about RCA HD52W56 52" Rear Projection HDTV
HD52W56 i have 52"rca(HD52W56). it was working fine till few days ago i heared noise in the back, plus it smelled like burning cables. i hope dont have to spend lots of $ for that junk. please help!!!!
  • zynda Dec 13, 2007
    ctf1800 thanks for response. i did took that sucker apart but didnt found nothing whats burned,Tv does not turn on , led light is not on either.
  • zynda Dec 15, 2007
    it was popping noise, does not smell anymore, all fuses are fine
  • 4,402 Answers
Take the cover off and look for something that is burnt and take a pic of it and attach it here.
Posted on Dec 11, 2007
  • Cary Farah
    Cary Farah Dec 13, 2007
    your not making this easy! describ the noise was it a bang, pop ?
    you said you smelled something can you peek inside and see if it get stronger in any area? does it smell like? arcing?
    can you see if any of fuses are blown?
  • Cary Farah
    Cary Farah Dec 15, 2007
    it could be high voltage cap located by flyback,if you have back off of
    tv and turn tv on,you will see green led's turn on,(on the board)if
    they turn off there is a small blue high voltage cap hidden under
    glue(i believe it's a 102 cap)that would be the one change,99% of time
    that is what will fix problem
Burning smell from drivers side rear wheel
This happens often on Fieros. It turns out that the clamp that holds the brake hose rusts. The rust presses against the hose, restricting it's flow. You don't notice when the brakes are worn and basically not working, but after repairs you get locked up or overheated brakes. Remove or replace clamp and or hose.
Oct 05, 2017 | 1995 Honda Accord
Metal snapping noise, like a broken spring, now burning smell. clutch?
Sounds like the throw-out bearing or the pressure plate has gone out..
Jun 24, 2017 | Cars & Trucks
I have a PSW-D112 that has little use, i just hooked it up 2 days ago and was working great and I shut it off by the switch on the back of the unit now today I went to turn it on and it made a buzzing...
What happens if you disconnect only the source end of the RCA's? Atmospheric noise can enter through the cables if their shields are grounded well.
Google: "speakers buzzing"
Aug 03, 2011 | JBL PSW-D110 Speaker
I purchased A Haier Dehumidifier 2 yrs ago on Aug 20/09( registered online) and it's been great...until today. i walked into the house, and the machine was making a VERY strange,high-pitched noise,...
Dont turn it back on your terminals on the compressor have vented causing all the freon and oil to leak out this is a fire hazzard. This dehumidifier is ready for the trash buy a new one soleus air is a lot better quality. Keep in mind all dehumidifiers are made very cheap so they are affordable and dont have a long life span. Let me know if this helps.
Jul 21, 2011 | Haier DM30EAL Dehumidifier
Hello, 3 months ago, I had my flyback on my 2006 RCA D52W20 HDTV rear projection replaced due to my t.v turning off and not coming back on. All was fine when after it was replaced, but still had a load...
The crt's on these sets have a nasty habit of leaking down onto the circuit boards and ruining them. If this has happened then it would cost more than it's worth to fix.
Oct 08, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W19 "crackles" and smells like its burning
Hello pmzone_guard, This problem is quite common in this TV it's due to a capacitor in the power supply being overloaded. The chassis model is a ITC222. The capacitor is located on the deflection board which is part of the power supply and should not be touch by someone that does not have TV Repair Experience, due to the fact that this area of the TV is the most dangerous. I would suggest having a qualified TV repair technician do the repair on this TV. If the problem is just that one capacitor the part will cost about $2.50 at the most, so the charge will be the cost of the part plus the labor involved. I hope this helps, Thank you, Shuttle83
Jun 14, 2009 | RCA D52W19 52" Rear Projection Television
Noise in my car amp.
sounds like you have a bad ground going to your rca's. try running a wire from ground to the shield of your rcas and see if the noise goes away.
Apr 19, 2009 | Rockford Fosgate Power 1050S Car Audio...
My 61 inch RCA HD TV started to shut of by itself.
RCA hdtv has a crackle then smell like something burning and then shuts off. What could the problem be
Mar 28, 2009 | RCA HD61W66 61" Projection HDTV
Bad sounds, bad smells from 94 ford explorer
Sounds like you may have a vacuum line off or ruptured going to the EGR valve. The burning smell is probably the catalytic converter. When the engine runs rich you will get a sulfur smell that smells sort of like rotten eggs.
Mar 15, 2009 | 1994 Ford Explorer Limited
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W56 52" Rear Projection HDTV Logo
96 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
