Question about Fuji FinePix S1000FD Digital Camera
How do the remove a display screen for a fujifilm finepix s1000 i have a replacement but cant undo two screws at base by tri-pod fixing point
    Brigadier General:
  • 11,967 Answers
Google the words...disassemble a digital camera.
Posted on Sep 12, 2009
Tri pod thread
I will say that a camera shop should not have any trouble taking care of your problem, they deal with this all the time.
Jan 23, 2013 | FUJIFILM FinePix HS10 / HS11 Digital...
MY finepix s5000 fujifilm camera has a white screen displaying when i turn it on, is there anyways i can fix that problem with out haveing to take it in.
Had the same problem with my s5700, white screen, took it apart. two screws on the left (facing the screen) under the strap, two in the usb compartment, two (screen side) screws on the bottom, three screw in the battery compartment, and the final just below the right side strap. Carefully pull the back off and check the ribbon connection from the lcd to the board. push it in made sure its seated. Reasemble being careful not to bend the ribbon connectors. Worked for me.
Aug 05, 2010 | Fuji FinePix S5000 Digital Camera
I have Fujifilm Finepix S1000. The battery door does not close. Is there a place on-line I can purchase a battery door? Thank you.
I know this is an old question, but when I had this problem I came across several forums that had the "tape it" or "drill a hole and screw it shut" solutions. Some even gave step by step instructions on taking the camera apart and replacing the battery compartment with one from a camera bought for parts. I even contacted Fujifilm for an estimate. All were either expensive, ineffective or damaging. The solution I came up with was to go to the Camera Exchange and buy a Quick Release plate used for tripods. One that was long enough to cover the battery door. It screws into the tripod mount on the back and holds the door closed. No damage, no hole drilling and it works. Also only cost me $8. Win!
Jan 18, 2010 | Fuji FinePix S1000FD Digital Camera
Why are my colors so wierd on the fujifilm finepix s1000? They are dull except for overly bright reds and some other colors...can this be fixed?
http://www.fujifilm.com/support/digital_cameras/software/firmware/s/finepix_s1000fd/index.html
Try to follow the instructions contained in this page to upgrade your camera firmware...
Nov 16, 2009 | Fuji Rod Repair Kit
Finepix F40fd: Need instructions for changing LCD screen
Remove the battery and leave the door open. The door operates a micro switch to shut power off to the camera.
Once you have a tri-wing screw driver start by removing the three tri-wing screws first. These should be located on the side where the hand strap is attached. Then you can undo the rest of the screws ( 5 on the bottom and 2 on the other side). Now pull the cowl away from the side of the camera with the hand strap. It should just unclip when you pull it. This should reveal the side of the two outer cases. The rear case is still attached on this side by a small screw and two more on the top by the zoom / picture button. Once these are removed lift the rear case up from the other end first so that you can release the ribbon for the keypad or just flip it over so that it lays flat next to the camera but still attached by the ribbon. the screen should now be visible but you may have to flip this over so that you can remove the bracket for the screen (the socket is visible underneath it and you can remove the screen with the bracket inplace but I find it easier to remove the bracket).
Be very careful when you lift the bracket clear as it is close to the flash and while the camera is off (and with the battery removed and the door open) the flash is still charged and can give quite a shock!
Now all you have to do is release the locking tab on the socket for the screen and remove the ribbon and then replace with the new one. Then reassmble the camera
Aug 05, 2009 | Fuji FinePix F40fd Digital Camera
My fujifilm S1000 keeps saying "Zoom Error"
same problem camera was dropped and have zoom error, since the lens and lcd are FINE i dont think it will be that much to fix
Mar 13, 2009 | Fuji FinePix S1000FD Digital Camera
Fujifilm F470: camera opens, shutter opens but no image!!!
I had the same problem with this particular camera. Here is the necessary steps to fix your problem.
1. Take out the battery because you dont want to short anything when you're inside it.
2. Free yourself of any static.
3. Remove six screws on the outside of the camera. Note that two of the screws in the botton are not phillips head. If you have a very small flat-head screw driver that will work.
4. Pull the camera apart very carefully. Unplug the little wiring harness by pulling up the little black clip that holds it in its seat.
5. Carefully remove the LCD screen. You dont have to remove any screws here. Just carefully pull it out. There is a peice of double sided tape that holds it in in place so you will fell some resistance.
6. Remove the two screws behind the screen that holds the lcd holder in place. Theres also one or two in the left side of that.
7. Plug back in the lens wiring harness. This is where your problem was. It came unplug from probably being dropped.
8. Repeat the steps 6,5,4,3,2, and 1 to put it back together.
Hope that this fixes your problem. It fixed my camera.
Dec 07, 2008 | Fuji FinePix F470 Digital Camera
Camera freezes after taking picture
I had this problem with my s1000 Fujifilm, but solved it by changing the standard SD card for a SDHC class 4 card. It no longer freezes when a flash is used! I've tried a 4Gb and a 16 GB SDHC class 4 card and both are fine.
Bazz
Nov 25, 2008 | Fuji FinePix S1000FD Digital Camera
Problem with uploading photos from fujifilm finepix s1000
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Aug 13, 2008 | Cameras
Fuji FinePix S1000FD Digital Camera Logo
264 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
