I just bought a SansDisk 2 GB memory card for the Nikon D70. When I inserted the card, all I got was a "CHA" flashing in the display. When I insert the card the green light lights up. However I can't format the disk and the camera won't take pictures. I took the card out and inserted three previous cards that I used to take pictures. The same result. I get a blinking "CHA" in the display. I took it to a camera store and the guy there took a look at it. He didn't understand it either. My battery is fully charged. Do you have any idea what might be causing this problem?
Jim Heitzig, Aptos, CA
-   I tried cleaning. still not working. any more ideas out there? thanks!-   Guest
Apr 10, 2009
-   My D70 has the same problem...I'm gonna try Sunriser's solution
-   godsgurl
Sep 10, 2008
-   I have the same exact problem with the D200, and cleaning the prongs didn't help.-   stinkonia
Mar 16, 2008
-   I was downloading pictures from my D70 when an error message came up on the viewscreen: "this card cannot be used" and the error message "CHA" began to flash.-   Guest
Try to clean the contacts of the memory cards and, mostly, of the memory card bay of the camera. Use a dry anti-static fabric (e.g. what we use to clean eye-glasses). DON'T use any liquid cleaner of anything like that!
This is a card reader problem. It can be caused by several things.
It could be:
Bad card. Try the card in another camera
Bad or bent contacts in the camera. This is a Nikon service Center fix.
Be sure the card is securely position in the camera. Don't force it, but it should feel seated. Sometinmes, turning it off, waiting a minute and turning it on clears the problem.
If none of these are a solution, then it could be the ribbon cable between the mother board and the CF slot. It's a common problem that many people have had. That's also a Nikon fix.
Let me know if any of this helped.
Was this helpful?
Yes
No
Popular Solutions for Nikon D70s Digital Camera with
Nikon 18-70mm lens just began sticking or jamming at 35mm. If I jiggle it awhile I can get to 70mm...
(More)
Nikon 18-70mm lens just began sticking or jamming at 35mm. If I jiggle it awhile I can get to 70mm but it will not go to 18mm.
