Question about Food Mixers
I want to grease the mixer head for my oster kitchen center but don't know what type of grease to use or where to buy it can you help?
    President:
  • Food Mixers Master
  • 1,922 Answers
You will need a "Food-Grade" white lithium grease,hardware stores should have it
Posted on Sep 12, 2009
Testimonial: "Thank you very much! I'll look the next time I'm at a hardware store."
My kitchen aid mixer is leaking oil or grease from the center shaft. When I opened the planetary there was grease in it. is there suppose to be grease there? is there a seal needed for the center shaft?
Hi TIOBEAN, by the symptoms you describe it appears the Center Shaft ‘O’-ring and quite likely the Transmission Gasket need to be replaced. You don’t mention how old your Artisan mixer is, but I assume it is out of warranty.
The internal gears of your mixer are factory packed with enough grease to last a 'lifetime'—whatever that means, and depending on the age of your mixer, where it was stored, degree and intensity of usage; these factors all contribute to the breakdown of the grease into its constituent parts (oil and suspenders), which have seeped beyond the gasket and ‘O’-ring, down the planetary (agitator shaft). Gravity can be very insidious. The residue coming from the agitator shaft is the gear lubricating grease oil that has come out of suspension.
So how bad is this oil leak problem and what can you do to fix it? First, if the amount of oil found leaking was small and if your mixer otherwise works normally with the missing oil you really don’t need to take your mixer apart to ‘fix’ it. The good news, though, is that you can take the mixer apart and 'fix' it, if you feel it is necessary.
It would be helpful to have the Part List manual as a reference. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home. Having the Parts List on hand will also be helpful as you will have to disassemble and reassemble your mixer to replace the ‘O’-ring and gasket.
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, KSM150 and select the file KSM150PSWH0.pdf (773.44 KB) listed for your model that appears under Parts List (61), and save that file to your PC.
Turn to pages 6 & 7, titled:”Case, Gearing And Planetary Unit” and locate Illus. No. 28, Center Shaft & O-Ring; particularly Illus No. 15 & 16, Transmission Gasket and ‘O’-Ring respectively. I suspect these parts have failed and will need to be replaced. Now the real fun begins!
To get to the Vertical Shaft you’ll need the following tools: a regular or Phillips screw driver, retaining clip pliers, and a small drift pin punch and a small hammer. After removing the Gearcase Motor Housing (mixer top) you will need to remove all the lubricating grease from the transmission housing and gears. This will allow you to remove Illus No. 11, 13, & 14, Bevel Pinion Center Gear, Pin (Vertical Center Shaft) and Groove Pin, respectively.
You should now be able to tap the Vertical Center Shaft (Illus. No. 12) down through the Lower Gearcase housing to access the ‘O’-ring.
Besides ordering a new ‘O’-ring (Illus. No. 16) and Transmission Gasket (Illus No. 15), you’ll also need to replace the grease you removed with new grease. Do not try to reuse any original grease as it may have ‘debris’ in it. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
With your mixer apart and the grease removed from the gears you can check them for any other unseemly wear and tear, too.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, determine what’s wrong, order the correct parts and reassemble your mixer.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Feb 09, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Need to add oil what type & where to add
Hi AQUA_1WELL, you want grease not oil.
Your KA mixer came supplied with a ‘lifetime’ supply of grease for lubricating your mixers transmission gears. However, over time that grease breaks down and it should be replaced as part of a regular maintenance regimen for your mixer.
The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM90P, and select one of the files listed under Parts List (check to see it this matches your mixer model).
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. This gearing is what you want to re-grease; as you disassemble the mixer head, you’ll see where what gears need grease and how much is used.
Ideally you want to replace the grease in your mixer with a ‘food grade’ grease (although I’ve see people use automotive bearing grease, too – your call.) Unfortunately you can’t just buy a ‘little’ grease, so the best option is to purchase a ‘cartridge’ and you’ll have enough to last you a lifetime of KA mixers. Try this link: http://www.grainger.com/Grainger/greases/ecatalog/N-9iv/Ntt-food+grade+grease?op=search&sst=All to get an idea of the grease available. You don’t necessarily need to purchase from Grainger, but when I fixed my wife’s mixer and needed to replace the grease in her mixer, the grease came from Grainger.
Here are five potential online vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer. Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Dec 22, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Oster regency parts
There are all kinds of Oster Kitchen Center parts and attachments for sale on Ebay. Here is another site that sells Regency parts: http://www.Goodman's.net
Can you help me with my Regency problem? I bought a used one with the hopes of using a lot of the attachments including a meat grinder (did not come with), but now after receiving the OKC there is no hole in the side of the mixer arm to attach the grinder - there is a metal circle. Do I need to punch out this circle - like an electrician does with an electrical box? HELP
Ladydirector@verizon.net
Dec 28, 2008 | Food Mixers
10 speed - 12 speed arms
Found the answer on the internet. THanks.
Nov 22, 2008 | Food Mixers
Instruction manual for oster kitchen center
how do iget the driver gear off
Sep 03, 2008 | Food Mixers
Oster kitchen center driver removal
http://www.oster.com/CustService.aspx
The customer service will help you to find the right answer to your question.The do also have technical repair center or they will tell you how to return the item for replacement.i used before and they work good
Jun 12, 2008 | Oster Food Mixers
Oster Kitchen Center won't hold a steady speed
My wifes Oster Kitchen Center slowed down and I think finally stopped. I say I think it did because I took it apart two years ago and am finally finding the time to get it back together. I cleaned it, checked the brushes on the motor(all of this is in the base unit with the control buttons on it. The upper blender/beater arm has no electrics in it.) The brushes were coated with some kind of dried crusty stuff which was keeping them from contacting the motor.I put it back together and tried it but it only hummed and did not move.
I took it apart again, this time everything came out. Motor, electric wiring plus the metal gearbox attached to the motor which drives the blender and the upper arm. I took the transmission apart (it's attached to the motor in the base unit) and found the gears in it were so gummed up with who knows what. Probably everything that leaked out of the blender.
You see, what happens is that the seal between the blender black base and the glass jar started to leak after a few years but we don't notice it. Maybe we did but we cleaned it and we thought it was all good. But the liquid can leak down into the bottom unit around the drive teeth and that little square drive that the blender locks onto. And then it goes into the gearbox and the motor. So it is a major job to clean it. Since I don't have a manual for disassembling the lower base unit, I'm just putting it back together. I cleaned all the gunk out, put some grease on the gears and the gearbox is working better but I fear not perfect. It is 30 years old!! So unless you take it apart yourself or find an appliance repair shop (is there such a place anymore?) it might not be worth the effort. But it is do-able. How long have you got?
Mar 01, 2008 | Food Mixers
Oster Regency kitchen center question
Look under the mixing head on the bowl side. There's a square "tab" that looks like the one on the back side of the machine. Pull it towards the bowl to release the mixer head from the base.
Oct 14, 2007 | Food Mixers
Food Mixers Logo
272 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
