Question about Whirlpool Dryers
When turnng the turn on switch, the dryer does not start. If I applly pressure on the door, it will start, but as soon as I take the pressure off, the dryer stops
    Problem Solver:
  • 7 Answers
Is there anything obstructing the door? Can you visually see the door switch? When you shut the door can you hear a click from the door switch activating?
Posted on Sep 12, 2009
My ken more dryer starts as soon as door closes (with out pushing the start bottom)it won't turn off unless I open door or unplug ....
faulty door safety switch
have it replaced
if no better
dryer has a timer/controller issue
Jun 18, 2016 | Dryers
Fisher paykel dryer ed56
Could be the door switch or temp sensor. To check the door switch put pressure against the door and see if it stops. Check the slot the door hits to see if there is anything loose in there.
Jul 20, 2013 | Dryers
My amana DLG330RAW dryer won't stay on. it has a combo timer and start dial turn the dial to the timed settinG and push...dryer starts part way through the cycle, the dryer...
Hello PB,
What i would most suspect as being the problem of why the dryer just stops randomly before the cycle is done,is a problem with the door switch or the door catch...does the dryer restart as soon as you restart it?? if yes i would check that the door catch was broken so the door will pop open stopping the dryer. Also check the door switch using a meter set to measure ohms and see if the contact is burnt ( a good door switch will be zero ohms resistiance)
GENE
Sep 17, 2011 | Amana DLG330RAW Gas Dryer
Model 63942101 Dryer Starts\Stops after Start buttton released.
Sounds like a bad door switch. Thats about all it can be. I see this from time to time but not often.
Please rate solution.
Aug 26, 2009 | Kenmore 63942 Dryer
Kenmore 70 series dryer problem
HI. This may be an issue concerning the pressure switch that is located inside the rim of the actual door.
This switch activates the main drum motor when a cycle is selected when you are ready to dry your clothes. As soon as you select the desired cycle and you load the clothes and shut the door, the last thing to do is push the start switch. if the door pressure switch is malfunctioning, it will not allow you to start the dryer. it will simply not spin.
If you can visibly see the light inside the drum/basket while the door is closed, this will confirm the malfunctioning pressure switch that is located inside the inner part of the door rim.
Its located in this position so that the actual door can make contact with it, in return, applying pressure to close the switch and complete the circuit. this will cause the dryer to spin.
You stated that you can see the drum light shinning when the door is closed and, this will confirm my diagnosis. You can preform a hard reset just to make sure of this defect. Simply unplug this unit for 5 minutes or, shut down the circuit breaker for 5 minutes as well. Any methods will work. Once the 5 minutes are up, simply plug back in this unit and try to run a normal cycle. if this problem is still and issue, it will once again confirm a door pressure switch failure and you will need to replace the switch in this unit.
I would check the wire clips and connectors as well located on this switch for lose or worn contacts. this can be a problem spot as well.
Please rate and god bless:)
Apr 26, 2009 | Kenmore Dryers
Start switch starts dryer but as soon as release d the dryer stops. Ifstart switch held in start position it turns and heats.
one of 2 things, your door switch is not working or the wires are shorted causing it not to work
Mar 26, 2009 | Dryers
Drum doesn't turn, start switch turns dryer on when held on but dryer shuts off as soon as start switch is released.
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Dec 02, 2008 | Dryers
Dryer starts on it's own when timer is turned or door is shut
its the door switch more than likely are less likely the push start button stuck
Mar 16, 2008 | Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
