Question about Poulan "Poulan" Push Mower
Poulan lawn mower, Briggs Stratton engine, revving problem
Lawn mower with Briggs Stratton engine, constantly revving fast then slow (approx. 3 second cycle), consuming too much gas. I've tried cleaning the air filter and adjusting the throttle springs, which has reduced the magnitude of the revving. However, mower still consuming about 3-4 times as much gasoline as it used to when it ran normally.
Mower is about 8 years old, but has seen perhaps 20 hours of service per year since my lawn is tiny. I've changed the spark plug but not the oil. I've tried regular vs premium gasoline, but that did not seem to make a difference.
Mower is not that expensive, so I don't want to pay a repair shop a lot of money if I can fix myself. I don't want to buy a new mower for such a small lawn if this one can be fixed easily. Thanks in advance for your help.
  • 389 Answers
Most likely problem is dirt?moisture in the carburetor float bowl. You would have to remove the bowl, clean it out and also clean the main jet up in the center of the carburetor. Another problem could be that the governor is out of adjustment but this is not something a novice could or should do
Posted on Sep 14, 2009
Won't pick up gas
what kind of mower and size and model is it.
Sep 28, 2014 | Briggs & Stratton Garden
Why does engine run at full trottle only?
Mark it sounds like there may be a problem with the air filter. If its revving and running to fast all the time clean the air filter.
Aug 01, 2014 | Briggs AND Stratton Intek Briggs &...
My engine is over revving
check air filter adjust carb may have to rebuild carb if wont adjust
Aug 04, 2012 | Briggs & Stratton Briggs Stratton...
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
I have a Poulan Pro lawnmower with 5.5 briggs that has been in storage for a few years. When i started it today it runs but the engine surges. Why is this.
There is a gasket/diaphragm between the carb and the fuel tank that has dried up and cracked and will need replacing. Model #: 5083D.You can purchase the replacement at Lowe's for $3 (Item #: 219691). Here are the directions for DIY:
Oct 04, 2011 | Briggs & Stratton Briggs Stratton...
Just looking for the type of oil I need to use for my poulan pro 625 series
Briggs and stratton sae 30 engine oil or any other reputable brand sae 30 engine oil is fine. Regards Phil
Apr 15, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Need to locate lawn mower ID No on a Briggs and Stratton lawn mower
The Model number for the Lawn Mower should be located under the seat or on the underside of the hood. The Model number for the engine should be on the top shroud usually in the front or above the carb.
May 03, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
YardMan U804H lawn tractor idles too fast
Might want to remove the blower housing and check for trash blocking governor mechanism.
Apr 13, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Poulan Pro lawnmower (Briggs and Stratton 128 cc engine) will start when primed but will not stay running. New Lawnmovewr, < 3 months since purchased at Walmart
IF IT IS A BRIGG & STRATTON ENGINE YOU CAN GO ONLINE TO BRIGGS & STRATTON.COM AND ASK THEIR TECH SECTION ABOUT THE PROBLEM. FOR 3 MONTHS OLD SOUNDS LIKE DIRT OR WATER MAY HAVE GOTTEN INTO THE TANK. WHEN YOU PRIME THE MOWER YOU ARE FORCING GAS INTO THE CARB AND ENGINE AFTER THAT THE ENGINE SHOULD PULL THE GAS IN THE ENGINE, I WOULD SAY THE CARB MITE NEED REBUILDING BUT NOT AT 3 MONTHS
Sep 17, 2009 | Poulan Garden
Briggs a stratton 35 lawn mower
Turn the mixture screw on the carburator slowly counter clock wise till the idel stabalizes.
Jul 01, 2009 | Champion International Champion& Small...
Poulan "Poulan" Push Mower Logo
1,193 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
