Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Picture is very bluury before that it had 3'd like lines in pink and green
    Scholar:
  • 101 Answers
The convergence IC's are bad. "red and green lines" For the blurry,You coolent needs to be changed. The blue and green crt usualy turn brown and milky.
Posted on Sep 12, 2009
I have pink and green wavy lines. Most pronounced at the bottom of the screen.
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Green and pink wavy lines throughout. Picture
I am having the same problem and so far unable to fix,
Jan 22, 2010 | Pioneer SD-582HD5 58" Rear Projection...
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Line pink and green
this would definitely won't be the lamp, the issue is either with you video board or the dmd board, go to the menu and if that line still shows up on the menu, the issue will be with your dmd board, on the contrary the issue would be with your digital video board
Jul 21, 2009 | Samsung HCN436W 43" Rear Projection...
Pink and green lines and double picture on Samsung big screen tv.
Replace the main bd. Have a trained Samsung tech troubleshoot to confirm.
Jul 08, 2009 | Samsung LN40A650A LCD TV
Pink and green lines running through my hitachi tv?
i have a hitachi projection tv and im getting blue lines behind the lettering and on different spots of the screen can anyone help
May 12, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
Picture distorted
this a problem with the motherboard. not the lamp.
Feb 05, 2009 | Toshiba 56HM195 56" Projection HDTV
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Pink picture with wavy green and blue lines
start with convergence ic's probably stk 392-130 big black chip's on an alluminum heat sink. mark ALL connections with majic marker. check for bad solder connections. for god's sake be carefull
Oct 19, 2006 | Sony KP-53S65 53" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
83 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
