Question about Sansui DTV2760 27" TV
Can't get local channels. tv still set for analog
Can't get clear video & audio of local channel in the Philippines.?
Posted on Sep 16, 2009
How can i rechannel my tv according to our local tv here in the philippines?
You will need to do a channel scan to locate the local signals.
This is in the menu of the TV format. The scan will go thru all of the tuners available channels both digital and analog, could take several minutes to complete depending on your set.
Feb 05, 2016 | Televison & Video
I am not a cable television subscriber. Nonetheless, why can't I get my local public television station when this television set tunes in all other local television stations (local ABC, CBS, NBC, Fox...
Some flat screen tv's have two inputs, one for digital and one for analog reception. If your local public television station is analog, then you'll need a signal input on the analog input.
You might try temporarily moving the input from the digital to the analog then doing a new channel scan to see if this picks up the PBS station. You'll have to rescan again, when you move your antenna lead in back to digital.
May 16, 2011 | Televison & Video
How do we scan/program in local tv channels. We bought an external antenna, but get no picture. Typically, there is a protocol for scanning channels into the set. Model is Sansui TVS2746B, and the set was...
Okay, does this tv have a built in DIGITAL tuner? Most tv's only have an analog tuner. You can tell the difference while you are changing the channels. If the channel indicates 2.1 or 2.2 and so forth, it is on a digital channel mode. If you change the channel and it indicated 2, 3, 4, etc. it is analog. If it has digital capability change the input until you see 2.1, 3.4 etc. If you cycle through all the inputs on the tv like, input 1 (TV) input 2(DVD) input 3(HDMI) and so forth and you never see the digital channel you most likely do not have a digital tuner. You will need to purchase a digital converter which will convert it to analog and you can watch it by placing you tv on analog channel 3 just like the old vcr's. Hope this helps and please don't forget to rate this solution.
Jan 22, 2011 | Samsung TSL2793HF 27" TV
How do i cahange my reception From analog to digital?
The Dynex LCD-19-09 19in LCD Tv has a digitial tuner in it already. I would recommend doing a channel scan and make sure it is on the "Antenna" setting instead of "Cable" and let it scan for channels. You will see all the analog channels like "7", "12" if they are still broadcasting, however, if you can pick up the digital channels, it will look more like "7-1" or 12-1; 12-2 etc.". To get to this, push the "Menu" button on the Dynex remote, then arrow down twice to TV, then push the right arrow and make sure it is set at Antenna and do a channel scan. Should get you whatever digital channels are available. If the digital antenna is not strong enough, you will need to get the digital one at Wal-Mart as previously suggested and hope that will convert the analog channels in your area.
Jun 12, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Can not get hd channels on my new tv..
First of all, digital/HD signals are broadcast at UHF frequencies. You need to know if you have an UHF antenna and, if you do, that it is pointed to the TV stations broadcasting HD.
Second, since most TV's have a setup mode that automatically searches for channels that are able to be received, go to that "Setup" menu on your TV and start the auto search. It will list both analog and digital stations. Note that the analog channel may be, for instance, Channel 39 but the digital channel will be Channel 39-1. Tune to the "dash 1" channel.
Dec 30, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
How do I set my PT-44LCX65 up to receive broadcast HDTV signals.
You should use the auto-program function in the customer menu. It will prompt you to select which antenna input you wish to program and then ask if you are on cable or receiving signals via "air" or "broadcast" mode. Allow the TV to load all the channels. You may notice that the auto program mode may move along quickly during the addition of analog channels and that during the scanning of the digital channels that it may look like nothing is happening. Patience is a virtue here. Wait until it has completely scanned both analog and digital bands and you will recieve both versions of the station's signal. If, for example, you have a local channel 5, the digital version will be 5-1, and so on.
michtech
Dec 18, 2008 | Panasonic PT-44LCX65 Television
Trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Jun 27, 2008 | Sanyo DS27910 27" TV
Cable
Don't know where you are from, however, if you are with mediacom or a similar Cable provider, They informed me that their cable box does the converting and will only work when your tv is set to Analog. So, searching for "digital" channels will get you no-where. Set and search channels in analog and you "should" receive digital. Call your local cable provider and see if they tell you the same. Silly question, but are you signed up for digital service???
Feb 11, 2007 | iLO 3200 32 in. LCD Television
Sansui DTV2760 27" TV Logo
49 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
