Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
How do you reconnect the two throttle rods on a Briggs 136212 006
I took it apart trying to get more speed out of the engine and now can not get it back together properly. Looking for diagams of the carb, throttle and governor.
    President:
  • 3,433 Answers
Go to this site or type into search
briggs &strattone ngine
bsppwebtools.com/data/manuals/1678_0esfw.pdf
Posted on Oct 31, 2009
Briggs and stratton sp 460 engine will idle but not rev
I suspect the push rod for your throttle isn't pushing the throttle lever down on the carb. When you move the lever up on the handle bar then it should move the lever down on the carb. The push rod my be bent, broke or rusted in place.
Mar 16, 2014 | Briggs & Stratton Garden
I have a briggs model 407777 that was idling up and down from near top range to bottom. Found some dust in the carb intake and decided to cliean the carb. When removing the manifold/ carb, I took loose...
These can be tricky, but your on the right track. With throttle set on high (engine off), turn governor linkage in the same direction that opens throttle valve in carb wide open, then turn the governor rod in that same direction then tighten bolt on governor arm. This is a static setting. The high and low idle is most likely a dirty carb so assuming the carb is now clean your idle should be better. Hope this helps. Good luck!
Aug 12, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Briggs and stratton 3.75 sprint engine handle throttle doesn't change speed
there is a long spring that goes from the level the cable connects to to the governor rod does that have any tension on it?
Apr 26, 2012 | Garden
Craftsman Mower - 625 Briggs and Stratton Engine. The mower starts after I prime it 3 times. Starts up and runs at only half speed. I have taken the whole thing apart, changed the gas, cleaned the carb,...
Check the governer, its a lever that pulls the throttle plate from the engine side. Try manually overriding it (twist it open as the engine's running) and see if that does it.
May 09, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Need pamphlet for Briggs,Stratton Eastern Lawnmower 2007 Took lawnmower apart, cannot find book on how to put it back together.
You must have model numbers to get any real help. If you mean you took the motor apart, you could go to www.briggsandstratton.com/ and download a manual.
Find your model number on your motor and enter on web site.
Aug 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Think i have a problem with governor on my 21hp v-twin briggs. it jumped to max speed and can't get it to slow down. which part of the governoring system could have let go?
Check for a broken spring on the governor linkage, follow your throttle control cable down to where it attaches to the throttle mechanism. In behind where the cable attaches you should be able to see a spring on the governor arm, the spring may have broken or somehow came out of its attaching point. Obviously be very careful about over-revving the engine, it could result in a broken connecting rod and a hole in the side of your crankcase.
Aug 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine runs ok until the blades are engaged, if I take the plug wire off the left side, it has no effect on the engine running.I changed plugs and checked the coil and wire, it has fire and compression. If...
Try to determine if the safety switch on the seat is closing or opening.
Does this happen when you are sitting on the seat and engage the blades?
You're ight, if you have gas and spark it should run, if the mixture is right.
Good luck on this one.
Jul 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Spring hook-ups throttle free design carb.
Spring goes from throttle air valve to plastic lever under flywheel. Cooling fan on flywheel provides pressure to open/close throttle. As engine (fan) speeds up, pressure on lever causes throttle to close. As engine slows, throttle will open. System achieves an equilibrium very quickly.
hope it helps!
May 30, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Throttle control not operating.
Need more information. Is your cable hooked up to the carb or broken? Try checking that. Rick
Apr 06, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
474 people viewed this question
Top Briggs & Stratton Hammering Experts
Dan Webster
Dan Webster
John Trevino
JOHN LAPIER
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
