Question about Kenmore Washing Machines
Code dl displays and buzzes. washer cannot be used
    Brigadier General:
  • 4,090 Answers
Overload error. Remove and redistribute some of the wash. But first unplug the machine for 4 hours to reset it
Posted on Sep 12, 2009
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
Sep 07, 2014 | Maytag Bravos MTW6600T Top Load Washer
Washer wont turn on. code is F dL. any thoughts?
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 07, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Mod110.28072800 580oasis washer
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool duet washer has error code f dl. there is a buzzing sound and the washer won't drain nor spin.
Hi there
I hope this helps you.
F/dL Door Lock Error
  • Door Lock Mechanism broken or removed from the Door
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Ty for writing to fix ya.
Best regards Richard
Dec 08, 2009 | Whirlpool GHW9150 Duet Washer
Washer displays dl when it attempts to lock the top and start the cycle.
Oct 08, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Machine won't turn on flashes dL F code and gives me short buzzes
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
Replace failed component.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
May 23, 2009 | Whirlpool Washing Machines
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer displays message of dl when trying to start washer
Hello bculwil Welcome
“dL” (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid
keeping it from closing. Press PAUSE/CANCEL once to clear
the code.
Or the lid lock sensor is faulty and needs to be diagnosed and replaced
Please remember to leave a solved rating before signing out.
Thank You Huum
Dec 21, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Problem
That is a door lock error code...check the latch and door strike for any damage, also try unplugging washer wait awhile and plug back in. If still get the f/dl than its time to replace either the door latch assembly or the main computer that controls it. Hope this helps - the doc
May 26, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
16 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
